[petsc-dev] PCCreate_BFBt has no manual page
Jed Brown jed at 59A2.org
Thu Mar 17 09:09:20 CDT 2011
On Sun, Feb 27, 2011 at 18:15, Barry Smith <bsmith at mcs.anl.gov> wrote:
> This exact text could go into the manual page. The problem now is that this
> information is in only one location (your head) and no one else knows if
> 1) BFBt is orthogonal to to lsc
> 2) BFBt is the replacement to lsc
> 3) BFBt is to be replaced with lsc.
> without consulting you.
Dave knows. :-)
Indeed, he just did the real work here and put in the MatNest support so
that the BFBt methods from his paper now run with LSC and produces identical
results. This has been merged into petsc-dev.
About this example, it's quite a hard problem and pretty small (32x32 Q1-P0
elements), but the matrices come from Underworld which we can't easily
include in a test. I'm inclined to put the matrix into datafiles and add the
test to the nightlies since it seems to be a discerning preconditioner
benchmark.
Now about whether to delete PCBFBT now or leave it around. I don't see a
problem with adding a man page that puts it in the "developer" level and has
a note that it is deprecated and LSC should be used instead, with a link to
this example for details on converting code.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110317/04ef65e7/attachment.html>
