[petsc-dev] configure issues
Wed Feb 9 04:33:09 CST 2011
On Wed, Feb 9, 2011 at 3:48 AM, Jed Brown <jed at 59a2.org> wrote:
> On Wed, Feb 9, 2011 at 10:26, Matthew Knepley <knepley at gmail.com> wrote:
>> 1) This is about fooling with the preprocessor, or I would not need any of
>> these goofy names. How can you deny this?
> The preprocessor doesn't care what the name of the macro is. Barry's
> suggestion was just a way to make it easy for a human to find out where the
> macro was set, but at the expense of making the names fragile. I would
> rather have the editor be able to navigate using more stable names.
>> 2) For test information as well as control flow, I want to stay in Python.
> How would you manage, say, the logic around PETSC_USE_X_FOR_DEBUGGER?
> Generate the appropriate snippets of code on the Python side? What advantage
> to you see to that?
A single system, with real scoping, easy debugging, more readable code, etc.
  Matt
>> 3) What do you mean by "link"?
> 1. From the name of a macro that may be defined in petscconf.h to the test
> in configure which is used to decide how to set that macro.
> 2. From the test in configure to a list of uses on the C side (in a less
> brute-force way than grep).
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110209/7bb6fe6d/attachment.html>
