[petsc-dev] Trying to get the CMake instructions to work, unsuccessfully
Jed Brown jed at 59A2.org
Wed Feb 2 10:03:08 CST 2011
On Wed, Feb 2, 2011 at 12:55, Satish Balay <balay at mcs.anl.gov> wrote:
> > rmills at ubuntu:~/proj/petsc-dev/ubuntu-gnu_g$ cmake ..
> You haeve to use 'make' or 'make -j 4' here - not 'cmake'
> I just do: [from petsc-dev]
> make -C ubuntu-gnu_g -j 4
Same here.  You should never have to invoke 'cmake' yourself unless you need
to reconfigure for a specific IDE instead of the default Makefiles (and some
IDEs, such as QtCreator and KDevelop4, will also do this for you).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110202/632e62bd/attachment.html>
