[petsc-dev] Question About Petsc ILU
Thu Dec 29 11:05:45 CST 2011
On Thu, Dec 29, 2011 at 11:01 AM, Dave Nystrom <dnystrom1 at comcast.net>wrote:
> I have recently added the capability to have a separate preconditioning
> matrix in the petsc interface for the code I am working with.  I have two
> types of preconditioning matrices that I have questions about.  One is
> tridiagonal and the other is 7 diagonals.  In both cases, the the diagonals
> are all lexically adjacent.  Or phrased differently, the tridiagonal matrix
> has a bandwidth of 3 and the 7 diagonal matrix has a bandwidth of 7 and so
> they are compact or dense band systems.
> I was wondering what petsc ilu will do for preconditioning matrices like
> these.  Will it produce an exact lu factorization or a nearly exact
> factorization?  I'm interested in the answer to this question because I am
> thinking I might be able to run this preconditioner on the gpu using the
> txpetscgpu package.
If you are running ILU(0), it has exactly the same nonzero pattern. The
convergence is unpredictably. I would consult Yousef Saad's book for
further information.
   Matt
> Thanks,
> Dave
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111229/a01c2335/attachment.html>
