[petsc-dev] Creation of snes->vec_func
Mon Dec 26 21:41:25 CST 2011
On Thu, Dec 22, 2011 at 11:49, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Can we
> > 1. Move the call to MatFindNonzeroRows() inside the if statement so it
> stops leaking for normal users.
>    Ok
> > 2. Change the if (0) to check a command line option. This will make your
> life easier when you want to tinker with it.
>    Don't bother, just label it as dead code that Barry refuses to let die.
Done:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/70d42c5830e2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111226/7e9d270e/attachment.html>
