[petsc-dev] Creation of snes->vec_func
Thu Dec 22 11:49:45 CST 2011
On Dec 22, 2011, at 10:27 AM, Jed Brown wrote:
> On Thu, Dec 22, 2011 at 10:23, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I understand it is never executed, what I described is why it is there and how it has been used in the past.
> Can we
> 1. Move the call to MatFindNonzeroRows() inside the if statement so it stops leaking for normal users.
   Ok
> 2. Change the if (0) to check a command line option. This will make your life easier when you want to tinker with it.
   Don't bother, just label it as dead code that Barry refuses to let die.
