[petsc-dev] Non-scalable matrix operations
Fri Dec 23 10:54:34 CST 2011
On Fri, Dec 23, 2011 at 10:48 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Dec 23, 2011, at 10:53 AM, Jed Brown wrote:
> On Fri, Dec 23, 2011 at 09:50, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> Humm, my G-S in not in PETSc and it is perfectly scalable.  It does have
>> more complex communication patterns but they are O(1) in latency and
>> bandwidth.  I'm not sure I understand your description above.
> It was more like, here's something that perhaps we want to put in PETSc,
> what rich communication pattern does it use, such that, if provided, the
> implementation would be simple?
> There is the implementation in Prometheus that uses my C++ linked lists
> and hash tables.  I would like to implement this with STLs.  I also hack
> into MPIAIJ matrices to provide a primitive of applying G-S on an index set
> of local vertices, required for the algorithm.  This should be rethought.
>  I would guess that it would take about a week or two to move this into
> PETSc.
> The complex communication required make this code work much better with
> large subdomains, so it is getting less attractive in a flat MPI mode, as
> it is currently written.  If I do this I would like to think about doing it
> in the next programming model of PETSc (pthreads?).  Anyway, this would
> take enough work that I'd like to think a bit about its design and even the
> algorithm in a non flat MPI model.
I think we should give at least some thought to how this would look in
Thrust/OpenCL.
   Matt
> Note, I see the win with G-S over Cheby in highly unsymmetric (convection,
> hyperbolic) problems where Cheby is not very good.
> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/eca66ab9/attachment.html>
