[petsc-dev] Non-scalable matrix operations
Mark F. Adams mark.adams at columbia.edu
Fri Dec 23 10:48:33 CST 2011
On Dec 23, 2011, at 10:53 AM, Jed Brown wrote:
> On Fri, Dec 23, 2011 at 09:50, Mark F. Adams <mark.adams at columbia.edu> wrote:
> Humm, my G-S in not in PETSc and it is perfectly scalable.  It does have more complex communication patterns but they are O(1) in latency and bandwidth.  I'm not sure I understand your description above.
> It was more like, here's something that perhaps we want to put in PETSc, what rich communication pattern does it use, such that, if provided, the implementation would be simple?
There is the implementation in Prometheus that uses my C++ linked lists and hash tables.  I would like to implement this with STLs.  I also hack into MPIAIJ matrices to provide a primitive of applying G-S on an index set of local vertices, required for the algorithm.  This should be rethought.  I would guess that it would take about a week or two to move this into PETSc.
The complex communication required make this code work much better with large subdomains, so it is getting less attractive in a flat MPI mode, as it is currently written.  If I do this I would like to think about doing it in the next programming model of PETSc (pthreads?).  Anyway, this would take enough work that I'd like to think a bit about its design and even the algorithm in a non flat MPI model.
Note, I see the win with G-S over Cheby in highly unsymmetric (convection, hyperbolic) problems where Cheby is not very good.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/fb894a14/attachment.html>
