[petsc-dev] Relocatable RPM for PETSc
Lisandro Dalcin dalcinl at gmail.com
Fri Dec 23 06:48:06 CST 2011
On 22 December 2011 13:57, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 22, 2011 at 10:32 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 22 December 2011 12:19, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Thu, Dec 22, 2011 at 9:11 AM, Chekuri S. Choudary
>> > <cchoudary at rnet-tech.com> wrote:
>> >> I am building an RPM for petsc-3.2-p5. I would like the users of the
>> >> RPM
>> >> to be able to mention the PETSC_DIR at installation time, i.e, the RPM
>> >> should be relocatable.
>> >> For example,
>> >> rpm –ivh  --prefix=$HOME/petsc
>> >> export PETSC_DIR=$HOME/petsc
>> >> The issue is that while building the RPM, the “configure –prefix=$DIR”
>> >> builds the package assuming that $DIR is the final location of the
>> >> files.
>> >> So, the only way seems to be to decide the
>> >> installation path upfront and make the RPM non relocatable.
>> >> Even with PETSC_DIR and PETSC_ARCH, it looks like the path is being
>> >> hardcoded, i.e, once PETSc is built, the files cannot be simply moved
>> >> by
>> >> changing PETSC_DIR and PETSC_ARCH. I was wondering if there is
>> >> workaround
>> >> for this issue or if I am missing anything.
>> > No, we do not support relocatable binary packages. There are too many
>> > things
>> > to do during the build.
>> Mmm... Are you shure? Looking at the code in config/install.py, I
>> would say that relocating a PETSc installation tree is just a matter
>> of fixing PETSC_DIR/PETSC_ARCH in a bunch of text files in conf/ ...
> Its in at least one C file, reg,c
Yes, but that code only matters if PETSC_USE_DYNAMIC_LIBRARIES.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
