[petsc-dev] Relocatable RPM for PETSc
Thu Dec 22 09:19:03 CST 2011
On Thu, Dec 22, 2011 at 9:11 AM, Chekuri S. Choudary <
cchoudary at rnet-tech.com> wrote:
> I am building an RPM for petsc-3.2-p5. I would like the users of the RPM
> to be able to mention the PETSC_DIR at installation time, i.e, the RPM
> should be relocatable.****
> For example, ****
> rpm –ivh  --prefix=$HOME/petsc****
> export PETSC_DIR=$HOME/petsc ****
> The issue is that while building the RPM, the “configure –prefix=$DIR”
> builds the package assuming that $DIR is the final location of the files.
> So, the only way seems to be to decide the****
> installation path upfront and make the RPM non relocatable.****
> Even with PETSC_DIR and PETSC_ARCH, it looks like the path is being
> hardcoded, i.e, once PETSc is built, the files cannot be simply moved by
> changing PETSC_DIR and PETSC_ARCH. I was wondering if there is workaround
> for this issue or if I am missing anything.
No, we do not support relocatable binary packages. There are too many
things to do during the build.
   Matt
> Thanks****
> Shiva****
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111222/d823000e/attachment.html>
