[petsc-dev] sacusp preconditioner - limited to seqaijcusp matrices?
Wed Dec 14 14:24:33 CST 2011
On Wed, Dec 14, 2011 at 2:21 PM, John Fettig <john.fettig at gmail.com> wrote:
> On Tue, Sep 20, 2011 at 12:58 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 20, 2011, at 11:54 AM, Brad Aagaard wrote:
>> > I tried running a PyLith simulation using the sacusp preconditioner
>> rather than ml. If I have the mat_type set to mpiaijcusp, I get an error
>> message that sacusp preconditioner only works with CUSP matrices. I checked
>> sacusp.c and the code checks to make sure the mat_type is seqaijcusp.
>>    Since the sacusp preconditioner is no MPI parallel it cannot deal with
>> MPI matrices. ML is a truly (MPI) parallel multi-level preconditioner so it
>> is not really interchangable with sacusp.
>>    You can use block Jacobi preconditioning -pc_type bjacobi -sub_pc_type
>> sacusp   with sacusp on each block.
> Hi Barry,
> Sorry to dig up a very old thread, but I just tried your suggestion of
> using block jacobi with sacusp on the blocks and I can't get it to work.
> For example, I run src/ksp/ksp/examples/tutorials/ex2.c with:
>  mpirun -np 2 ./ex2 -ksp_type cg -pc_type bjacobi -sub_pc_type sacusp
> -mat_type mpiaijcusp -vec_type mpicusp
> and it still bombs on line 139 of sacusp.cu because the vector type is
> not VECSEQCUSP.  What am I doing wrong?
You might need -vec_type cusp (should give seqcusp on 1 proc)
  Matt
> Thanks,
> John
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111214/f0b29551/attachment.html>
