[petsc-dev] CHOLESKY with MUMPS doesn't work properly
Alexander Grayver agrayver at gfz-potsdam.de
Fri Dec 9 13:33:15 CST 2011
Hong,
I configured PETSc from scratch and now it works, thanks.
BTW, in MUMPS after factorization I can get scaling vector  (MUMPS
scales matrix before factorization) easily mumid%ROWSCA.
This scaling vector was useful for me because of some kind of analysis.
Would it be possible to get it through PETSc somehow?
Alexander
On 09.12.2011 18:44, Hong Zhang wrote:
> Are you sure MUMPS is installed with petsc correctly?
>> [0]PETSC ERROR: No support for this operation for this object type!
>> [0]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc
>> CHOLESKY!
> Uses '-ksp_view' to check which solver is being used.
> Seems it calls petsc cholesky with mpiaij matrix.
> Petsc-dev supports mumps cholesky with mpiaij format, e.g.,
> petsc-dev/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2 -pc_type
> cholesky -pc_factor_mat_solver_package mumps -mat_type mpiaij
> Norm of error 1.53436e-15 iterations 1
> HOng
>> [0]PETSC ERROR: Petsc Development HG revision:
>> a4f22f4fcb371a016e046e537076dcfd2ce5087f  HG Date: Fri Dec 09 09:08:30 2011
>> -0600
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: /home/model on a openmpi-i named node233 by agrayver Fri Dec
>>   9 17:23:30 2011
>> [0]PETSC ERROR: Libraries linked from
>> /home/lib/petsc-dev/openmpi-intel-complex-release-f-ds/lib
>> [0]PETSC ERROR: Configure run at Fri Dec  9 16:51:10 2011
>> [0]PETSC ERROR: Configure options --download-metis --download-mumps
>> --download-parmetis --download-superlu_dist
>> --with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
>> --with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
>> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
>> --with-debugging=0 --with-fortran-interfaces=1 --with-fortran-kernels=1
>> --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
>> --with-petsc-arch=openmpi-intel-complex-release-f-ds --with-precision=double
>> --with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
>> --with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
>> --with-scalar-type=complex --with-x=0
>> PETSC_ARCH=openmpi-intel-complex-release-f-ds
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: MatGetFactor() line 3943 in
>> /home/lib/petsc-dev/src/mat/interface/matrix.c
>> [0]PETSC ERROR: PCFactorSetUpMatSolverPackage_Factor() line 17 in
>> /home/lib/petsc-dev/src/ksp/pc/impls/factor/factimpl.c
>> [0]PETSC ERROR: PCFactorSetUpMatSolverPackage() line 26 in
>> /home/lib/petsc-dev/src/ksp/pc/impls/factor/factor.c
>> Any idea?
>> Regards,
>> Alexander
