[petsc-dev] CHOLESKY with MUMPS doesn't work properly
Hong Zhang hzhang at mcs.anl.gov
Fri Dec 9 11:44:15 CST 2011
Are you sure MUMPS is installed with petsc correctly?
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc
> CHOLESKY!
Uses '-ksp_view' to check which solver is being used.
Seems it calls petsc cholesky with mpiaij matrix.
Petsc-dev supports mumps cholesky with mpiaij format, e.g.,
petsc-dev/src/ksp/ksp/examples/tutorials>mpiexec -n 2 ./ex2 -pc_type
cholesky -pc_factor_mat_solver_package mumps -mat_type mpiaij
Norm of error 1.53436e-15 iterations 1
HOng
> [0]PETSC ERROR: Petsc Development HG revision:
> a4f22f4fcb371a016e046e537076dcfd2ce5087f  HG Date: Fri Dec 09 09:08:30 2011
> -0600
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: /home/model on a openmpi-i named node233 by agrayver Fri Dec
>  9 17:23:30 2011
> [0]PETSC ERROR: Libraries linked from
> /home/lib/petsc-dev/openmpi-intel-complex-release-f-ds/lib
> [0]PETSC ERROR: Configure run at Fri Dec  9 16:51:10 2011
> [0]PETSC ERROR: Configure options --download-metis --download-mumps
> --download-parmetis --download-superlu_dist
> --with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
> --with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
> --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
> --with-debugging=0 --with-fortran-interfaces=1 --with-fortran-kernels=1
> --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
> --with-petsc-arch=openmpi-intel-complex-release-f-ds --with-precision=double
> --with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
> --with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
> --with-scalar-type=complex --with-x=0
> PETSC_ARCH=openmpi-intel-complex-release-f-ds
> [0]PETSC ERROR:
> [0]PETSC ERROR: MatGetFactor() line 3943 in
> /home/lib/petsc-dev/src/mat/interface/matrix.c
> [0]PETSC ERROR: PCFactorSetUpMatSolverPackage_Factor() line 17 in
> /home/lib/petsc-dev/src/ksp/pc/impls/factor/factimpl.c
> [0]PETSC ERROR: PCFactorSetUpMatSolverPackage() line 26 in
> /home/lib/petsc-dev/src/ksp/pc/impls/factor/factor.c
> Any idea?
> Regards,
> Alexander
