[petsc-dev] Error during compiling petsc-dev with Fortran
Alexander Grayver agrayver at gfz-potsdam.de
Wed Dec 7 05:22:01 CST 2011
Hi Matt,
Maybe you don't need IFC build.
More precisely,
in petscts.h90 there is only TSAdapt type which can't be found. It's
just used many times.
Alexander
On 07.12.2011 12:09, Matthew Knepley wrote:
> Satish,
>   Do we have an IFC build at ANL?
> People,
>   PUT YOUR TYPES IN FORTRAN,  or do not use automatic bindings.
>      Matt
> On Wed, Dec 7, 2011 at 4:33 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Matt,
>     Same is for SNESFASSetType in petscshes.h90
>     A lot of errors come from petscts.h90
>     So I deleted them all. Now it compiles.
>     Thanks.
>     Regards,
>     Alexander
>     On 07.12.2011 11:11, Matthew Knepley wrote:
>>     On Wed, Dec 7, 2011 at 4:01 AM, Alexander Grayver
>>         There are more:
>>     Repeat steps from below. This looks like test code.
>>        Matt
>>         [  0%] Building Fortran object
>>         CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o
>>         /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1058):
>>         error #5082: Syntax error, found END-OF-STATEMENT when
>>         expecting one of: ( % : . = =>
>>                MatTransposeColoring c ! MatTransposeColoring
>>         /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1063):
>>                MatTransposeColoring coloring ! MatTransposeColoring
>>         /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1070):
>>                MatTransposeColoring matcoloring ! MatTransposeColoring
>>         /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1079):
>>                MatTransposeColoring color ! MatTransposeColoring
>>         error #6622: This statement is invalid in an INTERFACE block.
>>         error #6218: This statement is positioned incorrectly and/or
>>         has syntax errors.
>>         has syntax errors.
>>         has syntax errors.
>>         has syntax errors.
>>         compilation aborted for
>>         /home/lib/petsc-dev/src/mat/f90-mod/petscmatmod.F (code 1)
>>         make[5]: ***
>>         [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o] Error 1
>>         make[4]: ***
>>         [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides]
>>         Error 2
>>         make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
>>         make[2]: *** [all] Error 2
>>         On 07.12.2011 10:39, Matthew Knepley wrote:
>>>         On Wed, Dec 7, 2011 at 3:33 AM, Alexander Grayver
>>>         wrote:
>>>             Hi Matt,
>>>             Unfortunately I don't have Mercurial installed on the
>>>             cluster (will negotiate it with admin soon), so I
>>>             downloaded tarball.
>>>             Is there a simple patch for that?
>>>         1) Just install it to your home dir. Its very small
>>>         2) Go to include/finclude/ftn-auto/petscviewer.h90, remove
>>>         lines 88--94
>>>           Matt
>>>             Regards,
>>>             Alexander
>>>             On 07.12.2011 10:32, Matthew Knepley wrote:
>>>>             On Wed, Dec 7, 2011 at 3:23 AM, Alexander Grayver
>>>>                 Hi dev-team,
>>>>                 Trying to compile petsc-dev with IFC 11.1 I got:
>>>>                 CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
>>>>                 /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/include/finclude/ftn-auto/petscviewer.h90(91):
>>>>                 when expecting one of: ( % : . = =>
>>>>                       PetscViewerVTKWriteFunction func !
>>>>                 INTERFACE block.
>>>>                 incorrectly and/or has syntax errors.
>>>>                 /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/src/sys/f90-mod/petscsysmod.F
>>>>                 (code 1)
>>>>                 make[5]: ***
>>>>                 [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o]
>>>>                 Error 1
>>>>                 make[4]: ***
>>>>                 [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides]
>>>>                 Error 2
>>>>                 How it can be fixed?
>>>>             Pull, make allfortranstubs, and the build again.
>>>>                Matt
>>>>                 Thanks in advance.
>>>>                 Regards,
>>>>                 Alexander
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111207/a3afa09c/attachment.html>
