[petsc-dev] Error during compiling petsc-dev with Fortran
Wed Dec 7 05:09:12 CST 2011
Satish,
  Do we have an IFC build at ANL?
People,
  PUT YOUR TYPES IN FORTRAN,  or do not use automatic bindings.
     Matt
On Wed, Dec 7, 2011 at 4:33 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Matt,
> Same is for SNESFASSetType in petscshes.h90
> A lot of errors come from petscts.h90
> So I deleted them all. Now it compiles.
> Thanks.
> Regards,
> Alexander
> On 07.12.2011 11:11, Matthew Knepley wrote:
> On Wed, Dec 7, 2011 at 4:01 AM, Alexander Grayver <agrayver at gfz-potsdam.de
> > wrote:
>>  There are more:
>  Repeat steps from below. This looks like test code.
>     Matt
>>  [  0%] Building Fortran object
>> CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o
>> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1058): error
>> #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( % : .
>>        MatTransposeColoring c ! MatTransposeColoring
>> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1063): error
>>        MatTransposeColoring coloring ! MatTransposeColoring
>> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1070): error
>>        MatTransposeColoring matcoloring ! MatTransposeColoring
>> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1079): error
>>        MatTransposeColoring color ! MatTransposeColoring
>> #6622: This statement is invalid in an INTERFACE block.
>> #6218: This statement is positioned incorrectly and/or has syntax errors.
>> compilation aborted for /home/lib/petsc-dev/src/mat/f90-mod/petscmatmod.F
>> (code 1)
>> make[5]: *** [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o] Error
>> 1
>> make[4]: ***
>> [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides] Error 2
>> make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
>> make[2]: *** [all] Error 2
>> On 07.12.2011 10:39, Matthew Knepley wrote:
>> On Wed, Dec 7, 2011 at 3:33 AM, Alexander Grayver <
>> agrayver at gfz-potsdam.de> wrote:
>>>  Hi Matt,
>>> Unfortunately I don't have Mercurial installed on the cluster (will
>>> negotiate it with admin soon), so I downloaded tarball.
>>> Is there a simple patch for that?
>>  1) Just install it to your home dir. Its very small
>>  2) Go to include/finclude/ftn-auto/petscviewer.h90, remove lines 88--94
>>    Matt
>>>  Regards,
>>> Alexander
>>> On 07.12.2011 10:32, Matthew Knepley wrote:
>>> On Wed, Dec 7, 2011 at 3:23 AM, Alexander Grayver <
>>>> Hi dev-team,
>>>> Trying to compile petsc-dev with IFC 11.1 I got:
>>>> CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
>>>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/include/finclude/ftn-auto/petscviewer.h90(91):
>>>> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
>>>>       PetscViewerVTKWriteFunction func ! PetscViewerVTKWriteFunction
>>>> error #6622: This statement is invalid in an INTERFACE block.
>>>> error #6218: This statement is positioned incorrectly and/or has syntax
>>>> errors.
>>>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/src/sys/f90-mod/petscsysmod.F
>>>> (code 1)
>>>> make[5]: *** [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o]
>>>> Error 1
>>>> make[4]: ***
>>>> [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides] Error 2
>>>> How it can be fixed?
>>>  Pull, make allfortranstubs, and the build again.
>>>     Matt
>>>> Thanks in advance.
>>>> Regards,
>>>>  Alexander
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111207/99e00e52/attachment.html>
