[petsc-dev] Duplicate configure option -with-metis=<bool> in section METIS
Václav Hapla vaclav.hapla at vsb.cz
Fri Dec 2 07:48:37 CST 2011
Thank you, this was exactly the problem, sorry.
Rgds,
Vaclav
Matthew Knepleyknepley at gmail.com  <mailto:petsc-dev%40mcs.anl.gov?Subject=Re%3A%20%5Bpetsc-dev%5D%20Duplicate%20configure%20option%20-with-metis%3D%3Cbool%3E%20in%0A%20section%20METIS&In-Reply-To=%3CCAMYG4GkBDQq9kn9ETFPVUUnGEZohRJppBuDY-z8yY3rLP7Ze1Q%40mail.gmail.com%3E>
Thu Dec 1 15:16:32 CST 2011
> 2011/12/1 Václav Hapla<vaclav.hapla at vsb.cz  <https://lists.mcs.anl.gov/mailman/listinfo/petsc-dev>>
> >  Hello,
> >  starting from rev 21292:6111c3453be1, I get the following message while
> >  running configure script:
> Are you sure that you also are up to date in the config/BuildSystem repo?
>     Matt
> >  UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> >  command line:
> >  ./configure --with-petsc-arch=debug-so-**gpu-mpich2-gnu-02
> >  --with-shared-libraries=1 --with-pic=1 --with-cuda=1
> >  --with-cuda-dir=/opt/cuda/4.0.**17 --with-thrust=1
> >  --with-thrust-dir=/opt/cuda/4.**0.17/include --with-cusp=1
> >  --with-cusp-dir=/opt --with-debugging=1 --with-lapack-dir=/usr/lib/**lapack
> >  --with-blas-dir=/usr/lib/**libblas --with-windows-graphics=0 --with-x=0
> >  --with-fortran=0 --with-cudac="nvcc -m64" --with-cuda-arch=sm_11
> >  Any ideas what's up? Is it a bug or my fault?
> >  Vaclav Hapla
> >  Research assistant
> >  SPOMECH project<http://spomech.vsb.cz/>
> >  Centre of Excellence IT4Innovations<http://www.it4i.eu/>
> >  tel.: (+420) 59 732 6291
> >  VSB-Technical University of Ostrava
> >  17.listopadu 15/2172
> >  708 33 Ostrava-Poruba
> >  Czech Republic
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111202/3cbf0a16/attachment.html>
