[petsc-dev] Duplicate configure option -with-metis=<bool> in section METIS
Thu Dec 1 15:16:32 CST 2011
2011/12/1 Václav Hapla <vaclav.hapla at vsb.cz>
> Hello,
> starting from rev 21292:6111c3453be1, I get the following message while
> running configure script:
Are you sure that you also are up to date in the config/BuildSystem repo?
   Matt
> UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> command line:
> ./configure --with-petsc-arch=debug-so-**gpu-mpich2-gnu-02
> --with-shared-libraries=1 --with-pic=1 --with-cuda=1
> --with-cuda-dir=/opt/cuda/4.0.**17 --with-thrust=1
> --with-thrust-dir=/opt/cuda/4.**0.17/include --with-cusp=1
> --with-cusp-dir=/opt --with-debugging=1 --with-lapack-dir=/usr/lib/**lapack
> --with-blas-dir=/usr/lib/**libblas --with-windows-graphics=0 --with-x=0
> --with-fortran=0 --with-cudac="nvcc -m64" --with-cuda-arch=sm_11
> Any ideas what's up? Is it a bug or my fault?
> Vaclav Hapla
> Research assistant
> SPOMECH project <http://spomech.vsb.cz/>
> Centre of Excellence IT4Innovations <http://www.it4i.eu/>
> tel.: (+420) 59 732 6291
> VSB-Technical University of Ostrava
> 17.listopadu 15/2172
> 708 33 Ostrava-Poruba
> Czech Republic
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111201/805c6046/attachment.html>
