[petsc-dev] bug in BuildSystem check
Fri Apr 22 09:16:58 CDT 2011
On Fri, Apr 22, 2011 at 8:28 AM, Jed Brown <jed at 59a2.org> wrote:
> On Fri, Apr 22, 2011 at 15:20, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > Are you sure?
>>     Absolutely!   I do not care if it links ok. We cannot use something
>> that doesn't have a proper prototype because (1) it spews crap all over a
>> PETSc build that worries people (rightly so) and (2) how can you trust the
>> link when you don't know how the compiler interpreted the arguments in the
>> compile.
> There is also the problem that if the prototype is not available, the
> argument will be implicitly converted from float to double which may change
> it's value. The standard actually requires that "isinf" and relatives be a
> macro, the type of the argument is checked and a more specific function
> (which may or may not be called isinf, and might be a compiler builtin) is
> called.
Okay, pushed something. Not yet tested.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110422/9d39a778/attachment.html>
