[petsc-dev] Fwd: [petsc-maint #69763] PETSc and OSKI
Fri Apr 8 10:07:42 CDT 2011
hm - 'hg log -f oski.py' shows the first addition as:
changeset:   14350:cdcbbfb81b3a
user:        barrysmith at barry-smiths-macbook-pro.local
date:        Sat Oct 03 11:10:07 2009 -0500
files:       config/PETSc/packages/oski.py src/mat/interface/f90-custom/zmatrixf90.c
description:
typo in matgetrowijf90() when PETSC_F90_2PTR_PROTO() exists, found in nightly tests
so some one sent this in e-mail [and barry added it in]?
satish
On Fri, 8 Apr 2011, Matthew Knepley wrote:
> On Fri, Apr 8, 2011 at 6:50 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  Who put this in and does it do anything?
> Jed did. As far as I know, this project is dead.
>    Matt
> >   Barry
> > Begin forwarded message:
> > > From: Kadir Akbudak <kadir at cs.bilkent.edu.tr>
> > > Date: April 8, 2011 6:42:40 AM CDT
> > > To: petsc-maint at mcs.anl.gov
> > > Subject: [petsc-maint #69763] PETSc and OSKI
> > > Reply-To: petsc-maint at mcs.anl.gov, Kadir Akbudak <
> > > Dear Sir or Madam,
> > > There is such a configuration script,
> > > petsc-3.1-p8/config/PETSc/packages/oski.py, in the PETSc distribution.
> > > Does this mean that PETSc uses OSKI sparse matrix-vector routines? If
> > > yes, is it possible to use shared libraries? It is written as:
> > > self.liblist   = [['oski/liboski_Tid.a','oski/liboski.a']] This means
> > > the libraries are static.
> > > In fact I want to use benefits of OSKI together with my sparse matrix
> > > ordering tool, in a numerical method which can be performed by PETSc.
> > > Yours Faithfully,
> > > Kadir
