[petsc-dev] .dir-locals.el
Sean Farley sean at mcs.anl.gov
Tue Nov 23 22:59:53 CST 2010
> Aquamacs handles this correctly.
See Barry's statement made May 9th:
"But I've found that Aquamacs is unbearable slow when doing global search
and replace with etags so I am back to Carbon Emacs. Does anyone have other
64 bit Emacs they would recommend?"
Perhaps 2.1 is faster now?
Either way, it seems there is a fix if you set "ns-pop-up-frames" to nil.
See this thread:
http://permalink.gmane.org/gmane.emacs.devel/128939
and he is quoting David Reitter from here:
http://comments.gmane.org/gmane.emacs.devel/125714
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101123/4b91f766/attachment.html>
