[petsc-dev] .dir-locals.el
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Tue Nov 23 22:54:25 CST 2010
"I have not switched from Carbon emacs because all the other ones,
include this one do not handle open -a Emacs afile the way I want it
to. It opens a NEW window (maybe Emacs calls them frames) of a
different size even, instead of reusing the current Emacs window. "
Aquamacs handles this correctly.
A
On Tue, Nov 23, 2010 at 9:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 23, 2010, at 6:43 PM, Sean Farley wrote:
>> Ok, I visited src/vec/vec/interface/vector.c and it didn't do a damn thing. Didn't ask me nothing or appear to have any affect. Emacs 22.3.1
>> Emacs 22.3.1??? Barry what kind of arcane emacs are you using? Carbon emacs? Why not use:
>> http://emacsformacosx.com/
>> It's cocoa and runs in 64bit which we all know is far superior than 32bit. It's double the bits! And yes, it is emacs 23.
>  I have not switched from Carbon emacs because all the other ones, include this one do not handle open -a Emacs afile the way I want it to. It opens a NEW window (maybe Emacs calls them frames) of a different size even, instead of reusing the current Emacs window.  Carbon emacs is the only one that reuses the window. Cannot find an option to change this, google finds a couple of people bitching about it but no fixes. And DO NOT tell me to use emacsclient or some other non-Mac OS way of doing open.  Once these imbeciles get this fixed then I will switch.
>   Barry
>> Sean
