[petsc-dev] Fwd: [petsc-maint #56111] petsc4py does not work with complex numbers?
Mon Nov 15 16:01:34 CST 2010
I get the following with complex enabled. Does this mean 'some tests
run but others fail'?
I guess we'll have to wait for Lisandro to reply..
Satish
asterix:/home/balay/tmp/petsc-dev/externalpackages/petsc4py-dev>make test
python test/runtests.py < /dev/null
[0 at asterix] Python 2.7 (/usr/bin/python)
[0 at asterix] PETSc 3.1.0-p5 development (conf: 'asterix64')
[0 at asterix] petsc4py 1.1.2 (build/lib.linux-x86_64-2.7/petsc4py)
.......................................................................................................................................................................................................................EE...................................................................................................F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F.......
 .F........F........F........F.........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F...................FE..........FF.FEF...........F.....................................................................................................................................................................................................................FFFF........FFFF................................................................F...F..F.......F...F..F.......F...F..F........
ERROR: testSetMonitor (test_ksp.TestKSPBCGSL)
Traceback (most recent call last):
  File "test/test_ksp.py", line 154, in testSetMonitor
    self.testSolve()
  File "test/test_ksp.py", line 132, in testSolve
    self.ksp.solve(b, x)
  File "KSP.pyx", line 326, in petsc4py.PETSc.KSP.solve (src/petsc4py.PETSc.c:89419)
Error: error code 62
[0] KSPSolve() line 427 in src/ksp/ksp/interface/itfunc.c
[0] KSPSolve_BCGSL() line 241 in src/ksp/ksp/impls/bcgsl/bcgsl.c
[0] VecMAXPY() line 1202 in src/vec/vec/interface/rvector.c
[0] Invalid argument
[0] Scalar value must be same on all processes, argument # 3
ERROR: testSolve (test_ksp.TestKSPBCGSL)
ERROR: testCreateTranspose (test_mat_py.TestDiagonal)
  File "test/test_mat_py.py", line 100, in tearDown
    self.assertEqual(getrefcount(ctx), 2)
AssertionError: 3 != 2
ERROR: testMultTransposeNewMeth (test_mat_py.TestIdentity)
On Mon, 15 Nov 2010, Barry Smith wrote:
> >    Could someone who knows answer this? If it supports complex then we'll need to change the flag in petsc4py.py
> >   Barry
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > Cannot use petsc4py with complex numbers it is not coded for this capability
> >   File "./config/configure.py", line 260, in petsc_configure
> >     framework.configure(out = sys.stdout)
> >   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/framework.py", line 977, in configure
> >     child.configure()
> >   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/package.py", line 488, in configure
> >     self.consistencyChecks()
> >   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/PETSc/package.py", line 40, in consistencyChecks
> >     raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability')
> > Begin forwarded message:
> >> From: Srinath Vadlamani <srinath at txcorp.com>
> >> Date: November 15, 2010 3:27:55 PM CST
> >> To: petsc-maint <petsc-maint at mcs.anl.gov>
> >> Subject: [petsc-maint #56111] petsc4py does not work with complex numbers?
> >> Reply-To: petsc-maint at mcs.anl.gov, Srinath Vadlamani <srinath at txcorp.com>
> >> Is this true?
> >> Srinath Vadlamani, PhD.
> >> Tech-X Corp. Research Scientist
> >> 5621 Arapahoe Ave. Suite A
> >> Boulder, CO 80303
> >> 303-996-2034
> >> Is this true?
> >> Boulder, CO 80303
> >> 303-996-2034
