[petsc-dev] Fwd: [petsc-maint #56111] petsc4py does not work with complex numbers?
Mon Nov 15 15:37:40 CST 2010
>    Could someone who knows answer this? If it supports complex then we'll need to change the flag in petsc4py.py
>   Barry
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Cannot use petsc4py with complex numbers it is not coded for this capability
>   File "./config/configure.py", line 260, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/framework.py", line 977, in configure
>     child.configure()
>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/package.py", line 488, in configure
>     self.consistencyChecks()
>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/PETSc/package.py", line 40, in consistencyChecks
>     raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability')
> Begin forwarded message:
>> From: Srinath Vadlamani <srinath at txcorp.com>
>> Date: November 15, 2010 3:27:55 PM CST
>> To: petsc-maint <petsc-maint at mcs.anl.gov>
>> Subject: [petsc-maint #56111] petsc4py does not work with complex numbers?
>> Reply-To: petsc-maint at mcs.anl.gov, Srinath Vadlamani <srinath at txcorp.com>
>> Is this true?
>> Srinath Vadlamani, PhD.
>> Tech-X Corp. Research Scientist
>> 5621 Arapahoe Ave. Suite A
>> Boulder, CO 80303
>> 303-996-2034
>> Is this true?
>> Boulder, CO 80303
>> 303-996-2034
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101115/142f012a/attachment.html>
