[petsc-dev] PETSc programming model for multi-core systems
Lisandro Dalcin dalcinl at gmail.com
Fri Nov 12 08:28:15 CST 2010
On 12 November 2010 11:09, Jed Brown <jed at 59a2.org> wrote:
> On Fri, Nov 12, 2010 at 15:04, Jed Brown <jed at 59a2.org> wrote:
>> The comparison we are more interested is with an equivalent number of MPI
>> processes per node.
> Whoops, missed your second attachment.  Indeed, that is what I expect,
> especially at relatively low node counts.  I think it has been fairly well
> demonstrated that straight MPI does alright for weak scaling with decent
> sized subdomains.  The trouble, and the place that threading (OpenMP or
> otherwise) offers an advantage, is for the very small subdomains you end up
> with when strong scaling.
Jed, Rodrigo's results are strong scaling. Unfortunately, we just had
4 cores I7 and 8 cores Xeon per node to test.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
