[petsc-dev] PETSc programming model for multi-core systems
Jed Brown jed at 59A2.org
Fri Nov 12 08:04:43 CST 2010
On Fri, Nov 12, 2010 at 14:51, Rodrigo R. Paz <rodrigop at intec.unl.edu.ar>wrote:
> IMHO, the main problem here is the low memory bandwidth (FSB) in Xeon E5420
> nodes.
This is well-known and fundamental (not dependent on the programming model).
 It appears that you are comparing OpenMP threading within a node to a
single thread.  The comparison we are more interested is with an equivalent
number of MPI processes per node.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101112/8553c489/attachment.html>
