[petsc-dev] Why did you remove my CUDA version check!!!
Fri Nov 5 14:07:49 CDT 2010
Matt,
I don't see self.setCompilers.compilerVersionCUDA in rev history. So I
think this code was broken when you added this stuff [and victor must
have tried to fix it..
You can revert relavent changes:
BuildSystem
 febbb50e3b78
 0d934bb871e4
 051ab1553c96
petsc-dev
 5a758fb106fc
You'll still see no compilerVersionCUDA in  setCompilers.py
[reverting these, and fixing self.setCompilers.compilerVersionCUDA might work..]
asterix:/home/balay/tmp/petsc-dev/config/BuildSystem>hg diff
diff -r 3d1e6fbcdc48 config/setCompilers.py
--- a/config/setCompilers.py    Fri Nov 05 09:03:09 2010 -0500
+++ b/config/setCompilers.py    Fri Nov 05 14:07:32 2010 -0500
@@ -513,7 +513,6 @@
   def checkCUDACompiler(self):
     '''Locate a functional CUDA compiler'''
-    requiredVersion = '3.2'
     if 'with-cudac' in self.framework.argDB and self.framework.argDB['with-cudac'] == '0':
       if 'CUDAC' in self.framework.argDB:
         del self.framework.argDB['CUDAC']
@@ -523,21 +522,7 @@
         if self.getExecutable(compiler, resultName = 'CUDAC'):
           self.checkCompiler('CUDA')
           # Put version info into the log
-          compilerVersion = self.executeShellCommand(self.CUDAC+' --version')
-          compilerVersion = compilerVersion[0]
-          compilerVersion = compilerVersion.split()
-          i = 0
-          for word in compilerVersion:
-            i = i+1
-            if word == 'release':
-              break
-          currentVersion = compilerVersion[i].strip(',')
-          if currentVersion != requiredVersion:
-            #raise RuntimeError('CUDA Error: PETSc currently requires nvcc version ' + requiredVersion)
-              print '==============================================================================='
-              print '** CUDA Error: PETSc requires nvcc version ' + requiredVersion + ' when compiling with --withcuda **'
-              sys.exit(3)
+          self.executeShellCommand(self.CUDAC+' --version')
           break
       except RuntimeError, e:
         self.logPrint('Error testing CUDA compiler: '+str(e))
Satish
On Fri, 5 Nov 2010, Matthew Knepley wrote:
> On Fri, Nov 5, 2010 at 1:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > because it was broken [as there was no
> > self.setCompilers.compilerVersionCUDA] - and I noticed a different
> > version check in setCompilers.py - and assumed thats the proper thing.
> > But looks like vicotr made a mistake by adding in that check in
> > setCompilers.py.
> > Still I don't see where self.setCompilers.compilerVersionCUDA was set
> > - and when that piece of cod removed..
> Dammit dammit dammit. Who is fucking with my code. It was in
> setCompilers.py.
> Everyone stop fucking with this while I fix it.
>     Matt
> > Satish
> > > That was the correct one. I took the one out
> > > of setCompilers.py for a reason.
> > >    Matt
