[petsc-dev] Why did you remove my CUDA version check!!!
Fri Nov 5 14:04:54 CDT 2010
On Fri, Nov 5, 2010 at 1:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 5, 2010 at 1:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> because it was broken [as there was no
>> self.setCompilers.compilerVersionCUDA] - and I noticed a different
>> version check in setCompilers.py - and assumed thats the proper thing.
>> But looks like vicotr made a mistake by adding in that check in
>> setCompilers.py.
>> Still I don't see where self.setCompilers.compilerVersionCUDA was set
>> - and when that piece of cod removed..
> Dammit dammit dammit. Who is fucking with my code. It was in
> setCompilers.py.
> Everyone stop fucking with this while I fix it.
Okay, now in setCompilers.py, we set the CUDA version. As Barry pointed out
before,
this should be done for all compilers and packages:
            self.compilerVersionCUDA = compilerVersion[i].strip(',')
and that is checked in cuda.py. Works for me.
  Matt
>     Matt
>> Satish
>> On Fri, 5 Nov 2010, Matthew Knepley wrote:
>> > That was the correct one. I took the one out
>> > of setCompilers.py for a reason.
>> >    Matt
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101105/f2c36ecc/attachment.html>
