[petsc-dev] configure failing because of old nvcc
Lisandro Dalcin dalcinl at gmail.com
Fri Nov 5 13:22:55 CDT 2010
On 5 November 2010 15:18, Satish Balay <balay at mcs.anl.gov> wrote:
> If so - perhaps the fix is to remove this check from Buildsystem
> [setCompilers.py - where it only determines cuda attributes like
> version - as stashes this info] - and place the version check back in
> cuda.py?
> Satish
That makes sense.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
