[petsc-dev] configure failing because of old nvcc
Fri Nov 5 13:18:02 CDT 2010
I think part of the issue is the configure model for compiler detection.
Perhaps we want buildsystem to detect/set compilers as it sees.  And
then petsc side of configure to check if this functionality exists -
and then use it? [with --with-cuda=1 flag in cuda.py?]
There was a recent change to do version check of nvcc in buildsystem -
instead of the prior check in cuda.py. [I just striped out the one
from cuda.py - because it was broken].
If so - perhaps the fix is to remove this check from Buildsystem
[setCompilers.py - where it only determines cuda attributes like
version - as stashes this info] - and place the version check back in
cuda.py?
Satish
On Fri, 5 Nov 2010, Barry Smith wrote:
>   You are correct, it should only stop on this if the user asked for --with-cuda  Victor can you fix this.
> On Nov 5, 2010, at 12:57 PM, Lisandro Dalcin wrote:
> > Do we really want this? Perhaps CUDA should be just disabled, instead
> > of configure failing? Note that I've not actually asked for a
> > CUDA-enabled build:
> > $ cat linux-gnu/conf/reconfigure-linux-gnu.py
> > #!/usr/bin/python
> > if __name__ == '__main__':
> >  import sys
> >  import os
> >  sys.path.insert(0, os.path.abspath('config'))
> >  import configure
> >  configure_options = [
> >    'PETSC_ARCH=linux-gnu',
> >    '--with-shared-libraries=1',
> >  configure.petsc_configure(configure_options)
> > [dalcinl at nikola dev]$ python linux-gnu/conf/reconfigure-linux-gnu.py
> >             Configuring PETSc to compile on your system
> > TESTING: checkCUDACompiler from
> > config.setCompilers(config/BuildSystem/config/se===============================================================================
> > ** CUDA Error: PETSc requires nvcc version 3.2 when compiling with --withcuda **
> >        CONFIGURATION CRASH  (Please send configure.log to
> > petsc-maint at mcs.anl.gov)
> > Lisandro Dalcin
> > CIMEC (INTEC/CONICET-UNL)
> > Predio CONICET-Santa Fe
> > Colectora RN 168 Km 472, Paraje El Pozo
> > Tel: +54-342-4511594 (ext 1011)
> > Tel/Fax: +54-342-4511169
