[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Thu Nov 4 10:47:01 CDT 2010
Satish -- here is another error from cloning just now.
The commands
    hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
    cd petsc-dev/config
    hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
    cd ..
    export PETSC_ARCH=arch-linux-gnu-c-debug
    export PETSC_DIR=$PWD
    ./configure --with-cc=mpicc --with-fc=mpif90
    --download-f-blas-lapack=1 --download-hdf5=1
And the output:
                  Configuring PETSc to compile on your system
    Compiling FBLASLAPACK; this may take several minutes
    TESTING: checkSharedLibrary from
    PETSc.packages.sowing(config/BuildSystem/config/package.py:455)
    Error! missing file:
    /home/cponder/CUDA/PFlotran/petsc-dev/src/ksp/pc/impls/gasm/makefile
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101104/7c4716de/attachment.html>
