[petsc-dev] Error building the latest PETSc
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 22:40:46 CDT 2010
*On 11/03/2010 09:26 PM, Barry Smith wrote:*
>     hg pull; hg update; cd src/sys/viewer/impls/hdf5; make
Ok -- that built fine!
                      Carl
ps -- I'm working through a problem with the PetscTruth still being used
in the SAMRAI code.
I still see a few instances in the PETSc code as well; is this something
that is supposed to go away?
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/061cecaa/attachment.html>
