[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 18:16:32 CDT 2010
*On 11/03/2010 06:07 PM, Satish Balay wrote:*
>     You have some contradictory statements here:
>     " Note that while I pulled BuildSystem,"
>     " although I'm skipping the steps"
>     " hg pull -u"
>     How did you pull BuildSystem - if not with 'hg pull -u'? [same
>     with petsc-dev]
>     [I'm assuming you've done 'hg clone' a few days ago - not today]
I did thehg clone this afternoon. When I do apull -u immediately after
cloning, it looks like it doesn't do anything. Should it?
         -- Carl
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/e4e331f2/attachment.html>
