[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 18:00:16 CDT 2010
*On 11/03/2010 05:43 PM, Satish Balay wrote:*
>     Perhaps you pulled petsc-dev - but not BuildSystem - so they are out-of-sync?
Satish -- here are the commands I used:
    hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
    cd petsc-dev/config
    hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
    cd ..
    export PETSC_ARCH=arch-linux-gnu-c-debug
    export PETSC_DIR=$PWD
    ./configure --with-cc=mpicc --with-fc=mpif90
    --download-f-blas-lapack=1 --download-hdf5=1
    --prefix=$PETSC_DIR/$PETSC_ARCH
    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
Note that while I pulledBuildSystem, I haven't taken any special steps
to install it, I just run the installation steps forpetsc-dev in the
parent directory.
This is what I get from reading
    http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html#Obtaining
although I'm skipping the steps
    hg pull -u
    ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
Are these necessary, given that I've pulled the updated trees and run
the configure & make?
                     Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/5ba7d803/attachment.html>
