[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 17:46:16 CDT 2010
On Wed, Nov 3, 2010 at 5:43 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Perhaps you pulled petsc-dev - but not BuildSystem - so they are
> out-of-sync?
With petsc-dev, sometimes changes are made that require reconfiguration
(like this one)
since the include is generated. If you pull BuildSystem and rerun configure,
it should be fine.
   Matt
> Satish
> On Wed, 3 Nov 2010, Carl Ponder wrote:
> > Satash -- the filepetsc-dev/include/petscsys.h contains a statement
> >    25   #if defined(__cplusplus)
> >    *26   #  define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_CXX*
> >    27   #else
> >    28   #  define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_C
> >    29   #endif
> > I don't see thisPETSC_FUNCTION_NAME_CXX declared anywhere in the source
> base,
> > and am running into errors of the form
> >    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h: In
> >    function 'PetscErrorCode PetscMemcpy(void*, const void*, size_t)':
> >    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1828:
> >    error: 'PETSC_FUNCTION_NAME_CXX' was not declared in this scope
> >    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1829:
> >    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1831:
> >    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1835:
> > when I build SAMRAI. Can you tell me what is missing?
> > Thanks,
> >             Carl Ponder
> > This email message is for the sole use of the intended recipient(s) and
> may
> > contain
> > confidential information.  Any unauthorized review, use, disclosure or
> > distribution
> > is prohibited.  If you are not the intended recipient, please contact the
> > sender by
> > reply email and destroy all copies of the original message.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/abedaa88/attachment.html>
