[petsc-dev] SAMRAI and PETSc
Boyce Griffith griffith at cims.nyu.edu
Mon Jun 21 11:45:07 CDT 2010
I maintain some code which is based on the original SAMRAI-PETSc
interface provided by SAMRAI --- basically, it creates/configures Vec
objects which use SAMRAI routines to evaluate the vector operations on
AMR data.  My code currently hooks together SAMRAI 2.4.4 and PETSc
(currently stuck at PETSc 3.0 until a bit later in the summer).  FWIW,
Rich Hornung tells me that a new SAMRAI release should be out later in
the summer, which will bring with it some fairly major API changes.
There is a public code repository here:
    https://code.nyu.edu/projects/show/ibamr
The library includes generic discretization stuff which is mainly
relevant for cell-centered finite-volume-type methods.
-- Boyce
On 6/21/10 12:33 PM, Barry Smith wrote:
> Dinesh,
> Bobby Philip is developing a version of PFLOTRAN that uses SAMRAI with
> PETSc and has been maintaining SAMRAI to work with petsc-dev. I don't
> know how much support he has for this but it would be great if that
> version of SAMRAI could be made available via a revision control system
> and shared by other groups. I also don't know if other people are
> using/developing SAMRAI at the moment. We could easily host a repository
> but don't have the people to maintain it ourselves.
> Barry
> On Jun 20, 2010, at 4:22 PM, Dinesh K Kaushik wrote:
>> Dear Barry,
>> I noticed that SAMRAI works with older versions of PETSc. Is this
>> correct? Some groups at KAUST are interested in using this package for
>> mesh adaptation.
>> Thanks,
>> Dinesh
