[petsc-dev] control configure summary output
Thu Jan 28 20:45:25 CST 2010
  Sstish,
    You could leave some of the information to be printed as it is now
and just print the
> ** Now build the libraries with "make PETSC_ARCH=asterix-foo
> PETSC_DIR=/home/balay/tmp/petsc-dev all"
manually at the end.
    Barry
On Jan 28, 2010, at 8:32 PM, Satish Balay wrote:
> On Thu, 28 Jan 2010, Barry Smith wrote:
>> On Jan 28, 2010, at 6:22 PM, Matthew Knepley wrote:
>>> However, its not clear to me that we need this. Rather, we might
>>> get away
>>> with just
>>> having PETSc.Configure() give this overall advice at the end.
>>> What do you think?
>>  Sounds like the way to go. Simple is good.
> Just to clarify - this means 'petsc:' section summary, and the 'make
> sugestion' is done by PETSc.Configure() - at the end - and everything
> else [compilers, packages etc..] remains the same?
> i.e only the following text is outputed from PETSc.Configure:
> PETSc:
>  PETSC_DIR: /home/balay/tmp/petsc-dev
>  PETSC_ARCH: asterix-foo
>  Clanguage: C
>  Scalar type: real
>  PETSc shared libraries: enabled
>  PETSc dynamic libraries: disabled
>  Memory alignment:16
> thanks,
> Satish
