[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 18:16:30 CST 2010
On Tue, Jan 26, 2010 at 6:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  You don't need ANY priveleges to install mercurial.
>   Satish, please verify that the tarball contains the right up to date
> BuildSystem.
>   I changed all the sizeof_xxx crap to the proper sizeof-xxx in types.py
> when I made the updates to this weeks ago.
Its not that. It is the pointer that is the problem. We translate it to
void_p.
  Matt
>   Barry
> On Jan 26, 2010, at 6:10 PM, Vijay S. Mahadevan wrote:
>  I do not have mercurial installed on my cluster and do not have the
>> priveleges to do so now. I used the tarball for petsc-dev from the
>> link in the site. Just do let me know if the tarball will contain this
>> update. Or if it is not too much trouble, I would appreciate it if you
>> can send me a patch.
>> Either way, do let me know which option will work for my situation.
>> Thanks.
>> Vijay
>> On Tue, Jan 26, 2010 at 6:04 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Pull PETSc and try again.
>>>  Matt
>>> On Tue, Jan 26, 2010 at 5:47 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I'm  trying to install the development copy of Petsc in a linux
>>>> cluster. The configuration proceeded fine until I had to run conftest
>>>> for the batch system. After running conftest in a node and then
>>>> running reconfigure on the main node, I get the following error.
>>>> Traceback (most recent call last):
>>>>  File "./reconfigure.py", line 25, in ?
>>>>  configure.petsc_configure(configure_options)
>>>>  File "/emchome/vijaysm/soft/petsc-3.0-dev/config/configure.py", line
>>>> 150, in petsc_configure
>>>>  check_for_option_mistakes(sys.argv)
>>>> 33, in check_for_option_mistakes
>>>>  raise ValueError('The option '+name+' should probably be
>>>> '+name.replace('_', '-'));
>>>> ValueError: The option --known-sizeof-void_p should probably be
>>>> --known-sizeof-void-p
>>>> I could not find the location where "--known-sizeof-" is read from or
>>>> else I could've tried to change this and reconfigure petsc. Do let me
>>>> know if there is a fix for this.
>>>> Thanks.
>>>> Vijay
>>> What most experimenters take for granted before they begin their
>>> experiments
>>> is infinitely more interesting than any results to which their
>>> experiments
>>> lead.
>>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100126/dae9f1df/attachment.html>
