[petsc-dev] [petsc-maint #40882] Re: ML changing the size of the coarse-level problem
Vijay S. Mahadevan vijay.m at gmail.com
Tue Jan 26 17:46:45 CST 2010
I'm really sorry about the previous email. This email does not belong
in this thread. I'll send a new email again and apologize for the
repetition.
Vijay
On Tue, Jan 26, 2010 at 5:45 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Hi,
> I'm  trying to install the development copy of Petsc in a linux
> cluster. The configuration proceeded fine until I had to run conftest
> for the batch system. After running conftest in a node and then
> running reconfigure on the main node, I get the following error.
> Traceback (most recent call last):
>  File "./reconfigure.py", line 25, in ?
>    configure.petsc_configure(configure_options)
>  File "/emchome/vijaysm/soft/petsc-3.0-dev/config/configure.py", line
> 150, in petsc_configure
>    check_for_option_mistakes(sys.argv)
> 33, in check_for_option_mistakes
>    raise ValueError('The option '+name+' should probably be
> '+name.replace('_', '-'));
> ValueError: The option --known-sizeof-void_p should probably be
> --known-sizeof-void-p
> I could not find the location where "--known-sizeof-" is read from or
> else I could've tried to change this and reconfigure petsc. Do let me
> know if there is a fix for this.
> Thanks.
> Vijay
