[petsc-dev] PETSC_USE_SOCKET_VIEWER macro - controlled by configure or not
Tue Jan 12 21:33:08 CST 2010
   Does make.log have errors in it? Probably.
    This is more a petsc-maint at mcs.anl.gov than a petsc-
dev at mcs.anl.gov email so please move any further discussion if needed
to there.
    Barry
On Jan 12, 2010, at 9:05 PM, Kevin.Buckley at ecs.vuw.ac.nz wrote:
>>> I am tying to help a researcher here build his application against
>>> a PETSc (3.0.0 p9) installtion at another site that seems to have
>>> undefined references to:
>>> PETSC_VIEWER_SOCKET_
>> Is this unresolved symbol from user code?
> No.
> They are all from within PETSc itself.
> Specifically, the various PETSc solvers that have the
> #ifdef(PETSC_USE_SOCKET_VIEWER )
> block I also forgot to mention in the body but alluded to in the
> subject. (You see, I did go digging in the code and libs!)
> To be a bit more verbose, on the machine I have no control over,
> other than to feed info to the installer there:
> for f in *.a ;do echo $f ; nm $f | grep PETSC_VIEWER_SOCKET_ ; done
> libpetsc.a
>         U PETSC_VIEWER_SOCKET_
> and so on for other PETSC libs.
> On my machine there's obvioulsy a fix up for that reference here:
> libpetsc.a
> 00001a4a T PETSC_VIEWER_SOCKET_
> What I could not discern from my inspection of the code so far
> was how the actual instatiation of the fix up for those references
> might have been binned on the other box, whilst the (U)ndefined
> references themselves still appear to have been compiled into the
> PETSc installation.
> I was expecting, once I had found it that is, PETSC_USE_SOCKET_VIEWER
> and a corresponding configure ability to turn it on/off, might control
> everything.
> Then I found the reference to tweaking it by hand on, admittedly
> an not quite run of the mill, platform.
> Hence my original question.
> Kevin M. Buckley                                  Room:  CO327
> School of Engineering and                         Phone: +64 4 463
> 5971
> Computer Science
> Victoria University of Wellington
> New Zealand
