[petsc-dev] dealing with MPIUNi
Fri Feb 26 14:54:22 CST 2010
On Feb 26, 2010, at 2:43 PM, Satish Balay wrote:
> Looks like uedge build tools look for mpiuni spearately and adds in
> -Impiuni.
> But I think its good to keep -Impiuni in petsc makefiles for
> regular users who have mpi.h [or mpif.h] in their non-petsc soures.
    I would like to avoid this.  Can't they just take out this special
case handling from the build tools or handle it by not adding anything?
   Barry
> Satish
> On Fri, 26 Feb 2010, Barry Smith wrote:
>> Satish,
>>  Ok I will expose the -Impiuni/ so that external packages can use
>> the MPI uni
>> directly. Please let me know if problems arise.
>>  Barry
>> On Feb 26, 2010, at 2:01 PM, Satish Balay wrote:
>>> I should have included facets-devel in this discussion. Will cc
>>> facets-devel list now [there are likely to be e-mail bounces due to
>>> this - will handle the bounces on petsc-dev]
>>> The discussion is at:
>>> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002200.html
>>> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002270.html
>>> The one usage I know off - is petsc+mpiuni is from uedge. I'm
>>> guessing
>>> there are other usages from facets [I don't really know these other
>>> usages]
>>> Based on the previous discussions on facets-devel list, I was
>>> advocating the following: when having sequential builds with
>>> multiple
>>> packages - that have their own internal seqmpi switch [with normal
>>> mpi
>>> code]:
>>> - the best thing to do is always use a proper mpi impl even for
>>> sequential builds - and make every package use this impl[ with
>>> perhaps an error message when parallel run is attempted]
>>> - if proper mpi must to be avoided - then one way to minise
>>> conflicts
>>> is use seq-mpi from only one package - and have others use this
>>> aswell. However this does not work with all packages [as there are
>>> some packages that do need MPI - like hypre etc..].
>>> So currently mpiuni is being used as the common seq-mpi [from uedge,
>>> and perhaps other codes]
>>> Wrt uedge I'm yet to check how the current changes might affect
>>> it. [currently uedge buildsystem does not work with petsc-dev [due
>>> to
>>> the makefile changes]. will check on this later.
>>>> If we switch back slightly to the old model in the following way
>>>> will that
>>>> resolve the problems with FACETS?
>>>> 1) expose the mpiuni include directory by adding the mpiuni
>>>> include path
>>>> to
>>>> the list of include search paths
>>> wrt uedge - the current buildsystem picks up everything from PETSc
>>> makefiles
>>> so the above change should work.
>>>> 2) DO NOT set PETSC_HAVE_MPI
>>> uedge does not use this - so this change should be fine.
>>>> 3) DO NOT have a separate mpiuni library (which doesn't exist
>>>> with single
>>>> library anyways).
>>> since uedge links with petsc+mpi detected from petsc makefiles -
>>> this
>>> should work..
>>>> Slightly related note: is there any reason not to always #if
>>>> defined(MPIUNI_AVOID_MPI_NAMESPACE) so that C mpi symbols don't
>>>> appear in
>>>> our
>>>> libraries. Not that this is important but I still like simple
>>>> clean code
>>>> without a bunch of confusing if not needed ifdefs.
>>> Looks like when this flag is defined - the fortran mpiuni symbols
>>> are
>>> also not built.
>>> satish
>>>> Barry
>>>> On Feb 26, 2010, at 1:00 PM, Barry Smith wrote:
>>>>> 1)  So FACETS Fortran code includes mpif.h directly AND includes
>>>>> PETSc
>>>>> includes in the same file? Can those extra includes just be
>>>>> removed from
>>>>> FACETS.
>>>>> 2)  Some FACES codes, or other packages that FACETS use THAT DO
>>>>> NOT use
>>>>> PETSc can/do use PETSc's mpiuni mpif.h?
>>>>> Are these ONLY conflict with the new MPI unimodel and FACETS or
>>>>> are
>>>>> there
>>>>> other conflicts?
>>>>> Is there any issue with not having a separate libmpiuni.a ?
>>>>> Barry
>>>>>>> On Feb 26, 2010, at 11:22 AM, Satish Balay wrote:
>>>>>>>> I think eliminating mpi.h, mpi.mod etc is not a good change.
>>>>>>>> Its
>>>>>>>> likely to break users codes.  I suspect it breaks FACETS. [and
>>>>>>>> perhaps
>>>>>>>> Flotran]
>>>>>>> Suspect isn't good enough. HOW does it break FACETS? It won't
>>>>>>> break
>>>>>>> pflotran
>>>>>>> unless they have #include "mpi.h" directly in their code
>>>>>> Just for this reason [prohibiting using 'mpi.h'/mpif.h from
>>>>>> user code
>>>>>> - if one wants --with-mpi=0] the current change is bad
>>>>>> I've explained the facets/uedge model used below.  I'll check
>>>>>> uedge
>>>>>> usage. I'll have to ask facets folks to check other usages..
>>>>>>>> With this change we will continue to have MPI symbols [esp from
>>>>>>>> fortran] in libpetsc.a. So this is not really clean
>>>>>>>> absorbtion of
>>>>>>>> mpiuni into petsc. And I don't think we can avoid having
>>>>>>>> these MPI
>>>>>>>> symbols in -lpetsc.
>>>>>>> Yes the fake "symbols" are in libpetsc.a but what is wrong with
>>>>>>> that?
>>>>>>> What
>>>>>>> is the disadvantage over having them in libmpiuni.a?
>>>>>>>> The fact that MPI API symbols exist in libpetsc.a makes PETSc
>>>>>>>> not
>>>>>>>> really pure plant. Its still a plant/animal - so the goal of
>>>>>>>> this
>>>>>>>> code
>>>>>>>> reorganization is still not met.
>>>>>>> As I said in my previous email; only Matt's plan is perfect.
>>>>>> My argument is - the change mode is still imperfect - but at
>>>>>> the cost
>>>>>> of breaking some user codes. [so its not worth the cost].
>>>>>>>> [I might not have raised this issue earlier wrt merging mpiuni
>>>>>>>> completely into petsc - thats my omission sorry about that.]
>>>>>>>> I suspec the following usage in FACETS/UEDGE will break with
>>>>>>>> this
>>>>>>>> change:
>>>>>>>> If you have package-A doing the same type of thing for its
>>>>>>>> sequential
>>>>>>>> implementation - it will have its own mpi_comm_size() etc
>>>>>>>> internally.
>>>>>>>> With this - mixing package-A with petsc-sequential will cause
>>>>>>>> duplicate symbol conflict.
>>>>>>> The fix is to not have any symbols in MPIUNI that are called
>>>>>>> MPI_xxx
>>>>>>> This is
>>>>>>> handled in mpiunis mpi.h with
>>>>>>> #if defined(MPIUNI_AVOID_MPI_NAMESPACE)
>>>>>>> we should just ALWAYS avoid the MPI Namespace
>>>>>>>> The way I'm currently resolving this issue is: Only one package
>>>>>>>> should
>>>>>>>> provide [internal] MPI - the other package is compiled with
>>>>>>>> --with-mpi=enabled.
>>>>>>>> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is
>>>>>>>> now
>>>>>>>> compiled with MPI-ENABLED - but links with PETSc - that
>>>>>>>> provides
>>>>>>>> MPIUNI - as MPI.
>>>>>>>> Also due to this - we added more stuff to MPUNI to cover all
>>>>>>>> MPI
>>>>>>>> symbol usage from FACETS.
>>>>>>>> So - the previous MPIUNI implementation scheme eventhough
>>>>>>>> slightly
>>>>>>>> inconsistant, provided good user interface - with minimal
>>>>>>>> maintainance
>>>>>>>> overhead.. Matt's schem makes everything consistant - but with
>>>>>>>> extra
>>>>>>>> maintainance overhead.
>>>>>>> We can certainly go back to the way it was if we need to. But
>>>>>>> you
>>>>>>> have
>>>>>>> not
>>>>>>> demonstrated that need, you've only speculated.
>>>>>>> Here is how it should work ok.
>>>>>>> 1) Several packages each use their own fake MPI, everything is
>>>>>>> fine
>>>>>>> unless two
>>>>>>> different mpi.h's get included but that should not happen.
>>>>>> One of the ways it can conflict is:
>>>>>> 'include' package1/mpif.h'
>>>>>> 'include mpiuni/mpif.h
>>>>>> and there will be duplicate variable conflicts for constants
>>>>>> like MPI_COMM_WORLD, and others.
>>>>>> I'll admit the old way of using mpiuni with other packages does
>>>>>> not
>>>>>> work with all packages. [only with a select few codes that facets
>>>>>> folks tested with].
>>>>>>> 2) Several packages each use PETSc's fake MPI. To support this
>>>>>>> we
>>>>>>> only
>>>>>>> need to
>>>>>>> have them add -I$PETSC_DIR/include/mpiuni in their compiles
>>>>>> In this case - the user should be consious that he needs mpiuni
>>>>>> from
>>>>>> user code - and enable another petsc build option? [or create
>>>>>> unportable makefile]. One more additional cost to the current
>>>>>> imperfect change.
>>>>>> So I still prefer the previous scheme.
>>>>>> Satish
>>>>>>>> So I still prefer previous secheme. If that not acceptable -
>>>>>>>> then
>>>>>>>> I
>>>>>>>> guess we have to go with Matt's scheme [ slplit up mpiuni
>>>>>>>> into a
>>>>>>>> different package, add build/make support to it - and deal with
>>>>>>>> all
>>>>>>>> the petsc-maint that creates..]. But the current change really
>>>>>>>> breaks
>>>>>>>> things - so we should not do this.
>>>>>>>> Satish
>>>>>>>> On Thu, 25 Feb 2010, Barry Smith wrote:
>>>>>>>>> After listening to our discussion of the half-plant/half
>>>>>>>>> animal
>>>>>>>>> handling
>>>>>>>>> of
>>>>>>>>> MPIUni I have adopted the plant :-) model.
>>>>>>>>> Background: All the packages in PETSc/packages and
>>>>>>>>> BuildSystem/config/packages
>>>>>>>>> have the following paradigm except MPI and BlasLapack.
>>>>>>>>> 1) PETSc can be built --with-package or --with-package=0
>>>>>>>>> 2) If --with-package=0 then there is no PETSC_HAVE_package
>>>>>>>>> defined,
>>>>>>>>> no
>>>>>>>>> extra
>>>>>>>>> libraries to link against and no extra include paths to look
>>>>>>>>> in
>>>>>>>>> BlasLapack breaks this paradigm in only one way! You cannot
>>>>>>>>> use
>>>>>>>>> --with-blaspack=0
>>>>>>>>> MPI breaks the paradigm more completely. You can use
>>>>>>>>> --with-mpi=0
>>>>>>>>> BUT if
>>>>>>>>> you
>>>>>>>>> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!!
>>>>>>>>> There is
>>>>>>>>> an
>>>>>>>>> extra
>>>>>>>>> library to link against and an extra include path to look in.
>>>>>>>>> The two possible solutions to resolve this perverse beast are
>>>>>>>>> 1) make mpiuni be a --download-mpiuni replacement for MPI,
>>>>>>>>> as we
>>>>>>>>> do
>>>>>>>>> --download-c-blaslapack (this would replace the current
>>>>>>>>> --with-mpi=0
>>>>>>>>> support).
>>>>>>>>> 2) better supporting --with-mpi=0 without breaking the
>>>>>>>>> paradigm
>>>>>>>>> I agree with Matt that 1 is the more elegant solution, since
>>>>>>>>> it
>>>>>>>>> fits
>>>>>>>>> the
>>>>>>>>> paradigm perfectly. But having --with-mpi=0 is easier and more
>>>>>>>>> understandable
>>>>>>>>> to the user then explaining about downloading a dummy MPI.
>>>>>>>>> Thus I have implemented and pushed 2). When you use --with-
>>>>>>>>> mpi=0
>>>>>>>>> 1) the macro PETSC_HAVE_MPI is not set
>>>>>>>>> 2) the list of include directories is not added to
>>>>>>>>> 3) the list of linked against libraries is not added to.
>>>>>>>>> I have implemented 2) and 3) by having in petsc.h (fortran
>>>>>>>>> also)
>>>>>>>>> #if defined(PETSC_HAVE_MPI)
>>>>>>>>> #include "mpi.h"
>>>>>>>>> #else
>>>>>>>>> #include "mpiuni/mpi.h"
>>>>>>>>> #endif
>>>>>>>>> and putting the dummy MPI stubs always into the PETSc
>>>>>>>>> libraries
>>>>>>>>> for
>>>>>>>>> both
>>>>>>>>> single library and multiple library PETSc installs.
>>>>>>>>> Note: this means one cannot have an include "mpi.h" in the uni
>>>>>>>>> case
>>>>>>>>> which
>>>>>>>>> bothered me initially but then Lisandro convinced me it was
>>>>>>>>> not
>>>>>>>>> a
>>>>>>>>> bad
>>>>>>>>> thing.
>>>>>>>>> The actual code changes to implement this were, of course,
>>>>>>>>> tiny.
>>>>>>>>> It
>>>>>>>>> is not
>>>>>>>>> perfect (only --download-mpiuni would be perfect :-), but it
>>>>>>>>> is
>>>>>>>>> better
>>>>>>>>> than
>>>>>>>>> before.
>>>>>>>>> Sorry Matt,
>>>>>>>>> Barry
