[petsc-dev] dealing with MPIUNi
Fri Feb 26 14:22:42 CST 2010
>> Slightly related note: is there any reason not to always #if
>> defined(MPIUNI_AVOID_MPI_NAMESPACE) so that C mpi symbols don't
>> appear in our
>> libraries. Not that this is important but I still like simple clean
>> code
>> without a bunch of confusing if not needed ifdefs.
> Looks like when this flag is defined - the fortran mpiuni symbols are
> also not built.
> satish
    I will change the C mpi.h for mpiuni to always mangle the symbol
names that go into the library. And remove the use of this flag there.
    Obviously this does not change the fact the Fortran MPI symbols
will be in the library but there is no easy fix to that.
    Barry
On Feb 26, 2010, at 2:01 PM, Satish Balay wrote:
> I should have included facets-devel in this discussion. Will cc
> facets-devel list now [there are likely to be e-mail bounces due to
> this - will handle the bounces on petsc-dev]
> The discussion is at:
> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002200.html
> http://lists.mcs.anl.gov/pipermail/petsc-dev/2010-February/002270.html
> The one usage I know off - is petsc+mpiuni is from uedge. I'm guessing
> there are other usages from facets [I don't really know these other
> usages]
> Based on the previous discussions on facets-devel list, I was
> advocating the following: when having sequential builds with multiple
> packages - that have their own internal seqmpi switch [with normal mpi
> code]:
> - the best thing to do is always use a proper mpi impl even for
>   sequential builds - and make every package use this impl[ with
>   perhaps an error message when parallel run is attempted]
> - if proper mpi must to be avoided - then one way to minise conflicts
>  is use seq-mpi from only one package - and have others use this
>  aswell. However this does not work with all packages [as there are
>  some packages that do need MPI - like hypre etc..].
> So currently mpiuni is being used as the common seq-mpi [from uedge,
> and perhaps other codes]
> Wrt uedge I'm yet to check how the current changes might affect
> it. [currently uedge buildsystem does not work with petsc-dev [due to
> the makefile changes]. will check on this later.
> On Fri, 26 Feb 2010, Barry Smith wrote:
>> If we switch back slightly to the old model in the following way
>> will that
>> resolve the problems with FACETS?
>> 1) expose the mpiuni include directory by adding the mpiuni include
>> path to
>> the list of include search paths
> wrt uedge - the current buildsystem picks up everything from PETSc
> makefiles -
> so the above change should work.
>> 2) DO NOT set PETSC_HAVE_MPI
> uedge does not use this - so this change should be fine.
>> 3) DO NOT have a separate mpiuni library (which doesn't exist with
>> single
>> library anyways).
> since uedge links with petsc+mpi detected from petsc makefiles - this
> should work..
>> appear in our
>> code
> also not built.
> satish
>>  Barry
>> On Feb 26, 2010, at 1:00 PM, Barry Smith wrote:
>>> 1)  So FACETS Fortran code includes mpif.h directly AND includes
>>> PETSc
>>> includes in the same file? Can those extra includes just be
>>> removed from
>>> FACETS.
>>> 2)  Some FACES codes, or other packages that FACETS use THAT DO
>>> NOT use
>>> PETSc can/do use PETSc's mpiuni mpif.h?
>>> Are these ONLY conflict with the new MPI unimodel and FACETS or
>>> are there
>>> other conflicts?
>>> Is there any issue with not having a separate libmpiuni.a ?
>>> Barry
>>>>> On Feb 26, 2010, at 11:22 AM, Satish Balay wrote:
>>>>>> I think eliminating mpi.h, mpi.mod etc is not a good change. Its
>>>>>> likely to break users codes.  I suspect it breaks FACETS. [and
>>>>>> perhaps
>>>>>> Flotran]
>>>>> Suspect isn't good enough. HOW does it break FACETS? It won't
>>>>> break
>>>>> pflotran
>>>>> unless they have #include "mpi.h" directly in their code
>>>> Just for this reason [prohibiting using 'mpi.h'/mpif.h from user
>>>> code
>>>> - if one wants --with-mpi=0] the current change is bad
>>>> I've explained the facets/uedge model used below.  I'll check uedge
>>>> usage. I'll have to ask facets folks to check other usages..
>>>>>> With this change we will continue to have MPI symbols [esp from
>>>>>> fortran] in libpetsc.a. So this is not really clean absorbtion of
>>>>>> mpiuni into petsc. And I don't think we can avoid having these
>>>>>> MPI
>>>>>> symbols in -lpetsc.
>>>>> Yes the fake "symbols" are in libpetsc.a but what is wrong with
>>>>> that?
>>>>> What
>>>>> is the disadvantage over having them in libmpiuni.a?
>>>>>> The fact that MPI API symbols exist in libpetsc.a makes PETSc not
>>>>>> really pure plant. Its still a plant/animal - so the goal of
>>>>>> this code
>>>>>> reorganization is still not met.
>>>>> As I said in my previous email; only Matt's plan is perfect.
>>>> My argument is - the change mode is still imperfect - but at the
>>>> cost
>>>> of breaking some user codes. [so its not worth the cost].
>>>>>> [I might not have raised this issue earlier wrt merging mpiuni
>>>>>> completely into petsc - thats my omission sorry about that.]
>>>>>> I suspec the following usage in FACETS/UEDGE will break with this
>>>>>> change:
>>>>>> If you have package-A doing the same type of thing for its
>>>>>> sequential
>>>>>> implementation - it will have its own mpi_comm_size() etc
>>>>>> internally.
>>>>>> With this - mixing package-A with petsc-sequential will cause
>>>>>> duplicate symbol conflict.
>>>>> The fix is to not have any symbols in MPIUNI that are called
>>>>> MPI_xxx
>>>>> This is
>>>>> handled in mpiunis mpi.h with
>>>>> #if defined(MPIUNI_AVOID_MPI_NAMESPACE)
>>>>> we should just ALWAYS avoid the MPI Namespace
>>>>>> The way I'm currently resolving this issue is: Only one package
>>>>>> should
>>>>>> provide [internal] MPI - the other package is compiled with
>>>>>> --with-mpi=enabled.
>>>>>> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is
>>>>>> now
>>>>>> compiled with MPI-ENABLED - but links with PETSc - that provides
>>>>>> MPIUNI - as MPI.
>>>>>> Also due to this - we added more stuff to MPUNI to cover all MPI
>>>>>> symbol usage from FACETS.
>>>>>> So - the previous MPIUNI implementation scheme eventhough
>>>>>> slightly
>>>>>> inconsistant, provided good user interface - with minimal
>>>>>> maintainance
>>>>>> overhead.. Matt's schem makes everything consistant - but with
>>>>>> extra
>>>>>> maintainance overhead.
>>>>> We can certainly go back to the way it was if we need to. But
>>>>> you have
>>>>> not
>>>>> demonstrated that need, you've only speculated.
>>>>> Here is how it should work ok.
>>>>> 1) Several packages each use their own fake MPI, everything is
>>>>> fine
>>>>> unless two
>>>>> different mpi.h's get included but that should not happen.
>>>> One of the ways it can conflict is:
>>>> 'include' package1/mpif.h'
>>>> 'include mpiuni/mpif.h
>>>> and there will be duplicate variable conflicts for constants
>>>> like MPI_COMM_WORLD, and others.
>>>> I'll admit the old way of using mpiuni with other packages does not
>>>> work with all packages. [only with a select few codes that facets
>>>> folks tested with].
>>>>> 2) Several packages each use PETSc's fake MPI. To support this
>>>>> we only
>>>>> need to
>>>>> have them add -I$PETSC_DIR/include/mpiuni in their compiles
>>>> In this case - the user should be consious that he needs mpiuni
>>>> from
>>>> user code - and enable another petsc build option? [or create
>>>> unportable makefile]. One more additional cost to the current
>>>> imperfect change.
>>>> So I still prefer the previous scheme.
>>>> Satish
>>>>>> So I still prefer previous secheme. If that not acceptable -
>>>>>> then I
>>>>>> guess we have to go with Matt's scheme [ slplit up mpiuni into a
>>>>>> different package, add build/make support to it - and deal with
>>>>>> all
>>>>>> the petsc-maint that creates..]. But the current change really
>>>>>> breaks
>>>>>> things - so we should not do this.
>>>>>> Satish
>>>>>> On Thu, 25 Feb 2010, Barry Smith wrote:
>>>>>>> After listening to our discussion of the half-plant/half animal
>>>>>>> handling
>>>>>>> of
>>>>>>> MPIUni I have adopted the plant :-) model.
>>>>>>> Background: All the packages in PETSc/packages and
>>>>>>> BuildSystem/config/packages
>>>>>>> have the following paradigm except MPI and BlasLapack.
>>>>>>> 1) PETSc can be built --with-package or --with-package=0
>>>>>>> 2) If --with-package=0 then there is no PETSC_HAVE_package
>>>>>>> defined,
>>>>>>> no
>>>>>>> extra
>>>>>>> libraries to link against and no extra include paths to look in
>>>>>>> BlasLapack breaks this paradigm in only one way! You cannot use
>>>>>>> --with-blaspack=0
>>>>>>> MPI breaks the paradigm more completely. You can use --with-
>>>>>>> mpi=0
>>>>>>> BUT if
>>>>>>> you
>>>>>>> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!!
>>>>>>> There is
>>>>>>> an
>>>>>>> extra
>>>>>>> library to link against and an extra include path to look in.
>>>>>>> The two possible solutions to resolve this perverse beast are
>>>>>>> 1) make mpiuni be a --download-mpiuni replacement for MPI, as
>>>>>>> we do
>>>>>>> --download-c-blaslapack (this would replace the current --with-
>>>>>>> mpi=0
>>>>>>> support).
>>>>>>> 2) better supporting --with-mpi=0 without breaking the paradigm
>>>>>>> I agree with Matt that 1 is the more elegant solution, since
>>>>>>> it fits
>>>>>>> the
>>>>>>> paradigm perfectly. But having --with-mpi=0 is easier and more
>>>>>>> understandable
>>>>>>> to the user then explaining about downloading a dummy MPI.
>>>>>>> Thus I have implemented and pushed 2). When you use --with-mpi=0
>>>>>>> 1) the macro PETSC_HAVE_MPI is not set
>>>>>>> 2) the list of include directories is not added to
>>>>>>> 3) the list of linked against libraries is not added to.
>>>>>>> I have implemented 2) and 3) by having in petsc.h (fortran also)
>>>>>>> #if defined(PETSC_HAVE_MPI)
>>>>>>> #include "mpi.h"
>>>>>>> #else
>>>>>>> #include "mpiuni/mpi.h"
>>>>>>> #endif
>>>>>>> and putting the dummy MPI stubs always into the PETSc
>>>>>>> libraries for
>>>>>>> both
>>>>>>> single library and multiple library PETSc installs.
>>>>>>> Note: this means one cannot have an include "mpi.h" in the uni
>>>>>>> case
>>>>>>> which
>>>>>>> bothered me initially but then Lisandro convinced me it was
>>>>>>> not a
>>>>>>> bad
>>>>>>> thing.
>>>>>>> The actual code changes to implement this were, of course,
>>>>>>> tiny. It
>>>>>>> is not
>>>>>>> perfect (only --download-mpiuni would be perfect :-), but it is
>>>>>>> better
>>>>>>> than
>>>>>>> before.
>>>>>>> Sorry Matt,
>>>>>>> Barry
