[petsc-dev] dealing with MPIUNi
Fri Feb 26 12:44:00 CST 2010
On Feb 26, 2010, at 12:01 PM, Satish Balay wrote:
> On Fri, 26 Feb 2010, Satish Balay wrote:
>> I think eliminating mpi.h, mpi.mod etc is not a good change. Its
>> likely to break users codes.  I suspect it breaks FACETS. [and
>> perhaps
>> Flotran]
>> With this change we will continue to have MPI symbols [esp from
>> fortran] in libpetsc.a. So this is not really clean absorbtion of
>> mpiuni into petsc. And I don't think we can avoid having these MPI
>> symbols in -lpetsc.
>> The fact that MPI API symbols exist in libpetsc.a makes PETSc not
>> really pure plant. Its still a plant/animal - so the goal of this
>> code
>> reorganization is still not met.
> I guess one way to make this a pure 'plant' is to have '#define
> MPI_Comm_size()' etc in mpiuni/mpif.h as well [but well have to
> somehow figureout how do do this for allcaps, all lowercase - usages -
> that the language allows].
   We could support three versions, all caps, all small and MPI C
style caps. Not perfect but will cover 99% of the users.
   Hmm mpi.mod could be a problem having two of them?
> But I'll have to figureout a different model for FACETS to interact
> with PETSc [with uni]. Maybe its possible [don't know as of now..]
    Please explain what the problem with the current model is with
FACETS?
That is I don't see how MY changes changed things enough to have any
impact on how
you handle things with FACETS?
    Barry
> Satish
>> [I might not have raised this issue earlier wrt merging mpiuni
>> completely into petsc - thats my omission sorry about that.]
>> I suspec the following usage in FACETS/UEDGE will break with this
>> change:
>> If you have package-A doing the same type of thing for its sequential
>> implementation - it will have its own mpi_comm_size() etc internally.
>> With this - mixing package-A with petsc-sequential will cause
>> duplicate symbol conflict.
>> The way I'm currently resolving this issue is: Only one package
>> should
>> provide [internal] MPI - the other package is compiled with
>> --with-mpi=enabled.
>> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is now
>> compiled with MPI-ENABLED - but links with PETSc - that provides
>> MPIUNI - as MPI.
>> Also due to this - we added more stuff to MPUNI to cover all MPI
>> symbol usage from FACETS.
>> So - the previous MPIUNI implementation scheme eventhough slightly
>> inconsistant, provided good user interface - with minimal
>> maintainance
>> overhead.. Matt's schem makes everything consistant - but with extra
>> maintainance overhead.
>> So I still prefer previous secheme. If that not acceptable - then I
>> guess we have to go with Matt's scheme [ slplit up mpiuni into a
>> different package, add build/make support to it - and deal with all
>> the petsc-maint that creates..]. But the current change really breaks
>> things - so we should not do this.
>> Satish
>> On Thu, 25 Feb 2010, Barry Smith wrote:
>>> After listening to our discussion of the half-plant/half animal
>>> handling of
>>> MPIUni I have adopted the plant :-) model.
>>> Background: All the packages in PETSc/packages and BuildSystem/
>>> config/packages
>>> have the following paradigm except MPI and BlasLapack.
>>> 1) PETSc can be built --with-package or --with-package=0
>>> 2) If --with-package=0 then there is no PETSC_HAVE_package
>>> defined, no extra
>>> libraries to link against and no extra include paths to look in
>>> BlasLapack breaks this paradigm in only one way! You cannot use
>>> --with-blaspack=0
>>> MPI breaks the paradigm more completely. You can use --with-mpi=0
>>> BUT if you
>>> use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!! There
>>> is an extra
>>> library to link against and an extra include path to look in.
>>> The two possible solutions to resolve this perverse beast are
>>> 1) make mpiuni be a --download-mpiuni replacement for MPI, as we do
>>> --download-c-blaslapack (this would replace the current --with-
>>> mpi=0 support).
>>> 2) better supporting --with-mpi=0 without breaking the paradigm
>>> I agree with Matt that 1 is the more elegant solution, since it
>>> fits the
>>> paradigm perfectly. But having --with-mpi=0 is easier and more
>>> understandable
>>> to the user then explaining about downloading a dummy MPI.
>>> Thus I have implemented and pushed 2). When you use --with-mpi=0
>>> 1) the macro PETSC_HAVE_MPI is not set
>>> 2) the list of include directories is not added to
>>> 3) the list of linked against libraries is not added to.
>>> I have implemented 2) and 3) by having in petsc.h (fortran also)
>>> #if defined(PETSC_HAVE_MPI)
>>> #include "mpi.h"
>>> #else
>>> #include "mpiuni/mpi.h"
>>> #endif
>>> and putting the dummy MPI stubs always into the PETSc libraries
>>> for both
>>> single library and multiple library PETSc installs.
>>> Note: this means one cannot have an include "mpi.h" in the uni
>>> case which
>>> bothered me initially but then Lisandro convinced me it was not a
>>> bad thing.
>>> The actual code changes to implement this were, of course, tiny.
>>> It is not
>>> perfect (only --download-mpiuni would be perfect :-), but it is
>>> better than
>>> before.
>>> Sorry Matt,
>>>  Barry
