[petsc-dev] dealing with MPIUNi
Fri Feb 26 12:01:22 CST 2010
On Fri, 26 Feb 2010, Satish Balay wrote:
> I think eliminating mpi.h, mpi.mod etc is not a good change. Its
> likely to break users codes.  I suspect it breaks FACETS. [and perhaps
> Flotran]
> With this change we will continue to have MPI symbols [esp from
> fortran] in libpetsc.a. So this is not really clean absorbtion of
> mpiuni into petsc. And I don't think we can avoid having these MPI
> symbols in -lpetsc.
> The fact that MPI API symbols exist in libpetsc.a makes PETSc not
> really pure plant. Its still a plant/animal - so the goal of this code
> reorganization is still not met.
I guess one way to make this a pure 'plant' is to have '#define
MPI_Comm_size()' etc in mpiuni/mpif.h as well [but well have to
somehow figureout how do do this for allcaps, all lowercase - usages -
that the language allows].
But I'll have to figureout a different model for FACETS to interact
with PETSc [with uni]. Maybe its possible [don't know as of now..]
Satish
> [I might not have raised this issue earlier wrt merging mpiuni
> completely into petsc - thats my omission sorry about that.]
> I suspec the following usage in FACETS/UEDGE will break with this
> change:
> If you have package-A doing the same type of thing for its sequential
> implementation - it will have its own mpi_comm_size() etc internally.
> With this - mixing package-A with petsc-sequential will cause
> duplicate symbol conflict.
> The way I'm currently resolving this issue is: Only one package should
> provide [internal] MPI - the other package is compiled with
> --with-mpi=enabled.
> I.e PETSc compiled with MPIUNI [says MPI_ENABLED]. Package-A is now
> compiled with MPI-ENABLED - but links with PETSc - that provides
> MPIUNI - as MPI.
> Also due to this - we added more stuff to MPUNI to cover all MPI
> symbol usage from FACETS.
> So - the previous MPIUNI implementation scheme eventhough slightly
> inconsistant, provided good user interface - with minimal maintainance
> overhead.. Matt's schem makes everything consistant - but with extra
> maintainance overhead.
> So I still prefer previous secheme. If that not acceptable - then I
> guess we have to go with Matt's scheme [ slplit up mpiuni into a
> different package, add build/make support to it - and deal with all
> the petsc-maint that creates..]. But the current change really breaks
> things - so we should not do this.
> Satish
> On Thu, 25 Feb 2010, Barry Smith wrote:
> > After listening to our discussion of the half-plant/half animal handling of
> > MPIUni I have adopted the plant :-) model.
> > Background: All the packages in PETSc/packages and BuildSystem/config/packages
> > have the following paradigm except MPI and BlasLapack.
> > 1) PETSc can be built --with-package or --with-package=0
> > 2) If --with-package=0 then there is no PETSC_HAVE_package defined, no extra
> > libraries to link against and no extra include paths to look in
> > BlasLapack breaks this paradigm in only one way! You cannot use
> > --with-blaspack=0
> > MPI breaks the paradigm more completely. You can use --with-mpi=0 BUT if you
> > use --with-mpi=0 then PETSC_HAVE_MPI is STILL defined!!!!!! There is an extra
> > library to link against and an extra include path to look in.
> > The two possible solutions to resolve this perverse beast are
> > 1) make mpiuni be a --download-mpiuni replacement for MPI, as we do
> > --download-c-blaslapack (this would replace the current --with-mpi=0 support).
> > 2) better supporting --with-mpi=0 without breaking the paradigm
> >  I agree with Matt that 1 is the more elegant solution, since it fits the
> > paradigm perfectly. But having --with-mpi=0 is easier and more understandable
> > to the user then explaining about downloading a dummy MPI.
> >  Thus I have implemented and pushed 2). When you use --with-mpi=0
> > 1) the macro PETSC_HAVE_MPI is not set
> > 2) the list of include directories is not added to
> > 3) the list of linked against libraries is not added to.
> > I have implemented 2) and 3) by having in petsc.h (fortran also)
> > #if defined(PETSC_HAVE_MPI)
> > #include "mpi.h"
> > #else
> > #include "mpiuni/mpi.h"
> > #endif
> > and putting the dummy MPI stubs always into the PETSc libraries for both
> > single library and multiple library PETSc installs.
> > Note: this means one cannot have an include "mpi.h" in the uni case which
> > bothered me initially but then Lisandro convinced me it was not a bad thing.
> > The actual code changes to implement this were, of course, tiny. It is not
> > perfect (only --download-mpiuni would be perfect :-), but it is better than
> > before.
> > Sorry Matt,
> >   Barry
