[petsc-dev] Murky
Sean Farley sean at mcs.anl.gov
Sun Feb 21 22:32:22 CST 2010
> 2/21/10 5:01:22 PM Murky[62152] *** NSTask: Task create for path
> '/usr/local/bin' failed: 13, "Permission denied".  Terminating temporary
> process.
This is really screwed up. What does the command:
/bin/bash --login -c '/usr/local/bin/hg --version'
give you?
barry-smiths-macbook-pro:~/Src/petsc-dev] barrysmith% ls -ld /usr/local/bin
> drwxr-xr-x  73 root  wheel  2482 Jan  8 12:52 /usr/local/bin/
> [barry-smiths-macbook-pro:~/Src/petsc-dev] barrysmith% ls -l
> /usr/local/bin/hg
> -rwxr-xr-x  1 root  wheel  860 Jan  8 12:52 /usr/local/bin/hg*
Why is it "Permission denied"? Everyone can read/execute! What does the '*'
mean at the end of the last line?
Perchance, are you running zsh or csh? Murky hardcodes bash to do it's
process spawning...
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100221/00b20e94/attachment.html>
