[petsc-dev] [petsc-maint #42006] TAO is broken
balay at mcs.anl.gov balay at mcs.anl.gov
Thu Feb 18 13:36:16 CST 2010
Ok.
the way single-lib is implemented - PETSC_ARCH/conf/petscvariables
has:
LIBNAME = ${INSTALL_LIB_DIR}/libpetsc.${AR_LIB_SUFFIX}
This overwrites conf/variables and makefile [in src makefile].  This
affected mpiuni - and now it affects tao [and will probably affect
slepc]
So we have to remove the hacks in PETSC_ARCH/conf/petscvariables [that
are in place for single-lib] - and see if its possible to implement it
differently
Perhaps this is a petsc-dev issue - so forwarding to petsc-dev
Satish
On Thu, 18 Feb 2010, Matthew Knepley wrote:
> No error, it just makes libpetsc.a instead of the TAO library names.
>    Matt
> On Thu, Feb 18, 2010 at 11:22 AM, Satish Balay <petsc-maint at mcs.anl.gov>wrote:
> > We don't have access to TAO repo.. You should check this with Jason.
> > [cc:ing jason]
> > Wrt single-lib stuff - what are the errors? I worked a bit on making
> > sure TAO makefiles are compatible with PETSc makefiles - so I can
> > check that..
> > Satish
> > > The single lib has broken the TAO build. It puts everything in
> > libpetsc.a.
> > > Do
> > > we have access to the TAO repo? There are some other fixes Blaise has to
> > > push in.
> > >   Thanks,
> > >      Matt
