[petsc-dev] forget about libmpiuni completely
Lisandro Dalcin dalcinl at gmail.com
Wed Feb 17 10:32:56 CST 2010
On 17 February 2010 13:06, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 17, 2010, at 9:05 AM, Lisandro Dalcin wrote:
>> On 17 February 2010 11:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> 1) Make mpiuni truly a download package mimicing other ones exactly.
>>> 2) Swallow mpiuni more completely into PETSc, no separate libmpiuni, put
>>> the
>>> includes/mods in a location they are found automatically without the
>>> extra
>>> -IXXXX
>>> 3) Have a half-plant/half-animal model.
>> I definitely vote for (2) ... No separate libmpiuni (put stuff
>> libpetscsys), put mpi.*.* in  ${PETSC_ARCH}/include/
>> However, just in case (think of ./configure --with-mpi=0 --prefix=/usr)
>> I think we could do the following:
>> 1) rename/move "include/mpiuni/mpi.h" to "include/mpiuni.h"
>> 2) autogenerate a header file "$PETSC_ARCH/include/petscmpi.h",
>> #include'ing "mpi.h" or "mpiuni.h" depending on configuration.
>> 3) Change "petsc.h" to #incluide "petscmpi.h" instead of "mpi.h"
>   Yuck. Users often like to shove a #include "mpi.h" into their source code
> (even though, of course, when you include petsc.h you don't need to worry
> about that), with your model it pushes people too much into a "PETSc way".
>   Your model is clean, but too idealistic I think and would annoy people.
But if they shove a #include "mpi.h" into their source code, things
will work, as long as they use a true MPI implementation... My point
is that if users do want to maintain its code mpiuni-compatible, they
should not #include "mpi.h", and let #include "petsc.h" handle the MPI
details...
Anyway, I'm fine with having $PETSC_ARCH/include/mpi*.* ... It's just
that I have a bit of fear about a prefix PETSc install --with-mpi=0
overwriting the mpi.h from a true MPI installation... I know, this
situation is kinda nonsense, but you know...
Lisandro Dalcin
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
