[petsc-dev] [petsc-maint #45539] petsc installation failure
Fri Apr 30 12:58:08 CDT 2010
    Ok, looks like there is no way to write a "universal test example"
that is run initially to see if executables can be run or if batch
system is needed.
     So we need to rig it that if any executable run (for checking
sizeof etc) cannot run that it generates the nice error messages about
--with-batch
     I have added it to the checkRun() tests in types.py that
triggered the problem for this guy.
     Barry
On Apr 30, 2010, at 11:41 AM, Satish Balay wrote:
> Barry,
> The code that crashed for me is the fortran configure test [not the c
> configure test].
> login1.surveyor:~/junk > cat foo.F
>                       program main
>                       write (*,*) 'hello'
>                       end
> login1.surveyor:~/junk > mpif90 foo.F
> ./a.out
> login1.surveyor:~/junk > ./a.out
> Illegal instruction
> Note: one difference between the machines BG/L and
> BG/P are the version of gnu compilers used. [gcc 3 vs gcc 4]. And the
> results could be different for IBM compilers. [Didn't try yet].
> Satish
> On Fri, 30 Apr 2010, Barry Smith wrote:
>>   If you don't change ./configure then which code does not run on our
>> BG and triggers the "crash" of .configure. Is it the same one that
>> did
>> for that guy? If you then compile and run that code standalone
>> outside
>> of .configure does it not run?
>>     Barry
>> On Apr 29, 2010, at 9:20 PM, Satish Balay wrote:
>>> On Thu, 29 Apr 2010, Barry Smith wrote:
>>>>   THIS IS INSANE! What a stupid useless error message. Why isn't it
>>>> suggesting --with-batch???
>>>>    Well, look what happens -----
>>>> In checkCCompiler() it builds an executable and seems to run
>>>> without
>>>> error. This is where configure checks for failed running and prints
>>>> the helpful --with-batch option. But since the "execute" succeeds
>>>> no
>>>> useful error message.
>>>> Then several other executables seem to run fine.
>>>> Then it builds the sizeof(char) test code and that is not
>>>> executable
>>>> and hence the terrible "Unable to determine ..." error message.
>>> Yes - some code compiled for compute nodes also run on the
>>> frontend -
>>> but not all..
>>>>   Satish,
>>>> Does this same problem occur on our BG?
>>> Nope.. I get:
>>> login1.surveyor:~/petsc-release-3.1 > ./configure --with-fc=mpif77
>>>            Configuring PETSc to compile on your system
>>> TESTING: checkFortranCompiler from config.setCompilers(config/
>>> BuildSystem/config/setCompilers.py:742)
>>>                   UNABLE to EXECUTE BINARIES for config/configure.py
>>> Cannot run executables created with FC. If this machine uses a batch
>>> system
>>> to submit jobs you will need to configure using/configure.py with
>>> the additional option  --with-batch.
>>> Otherwise there is problem with the compilers. Can you compile and
>>> run code with your C/C++ (and maybe Fortran) compilers?
>>>> Can you have the original test of the executable in
>>>> checkCCompiler()
>>>> make a code with a print statement in it and see if that is not
>>>> executable and hence stops with the correct error message?
>>> I have tested with sizeof.c [in src/benchmarks] and this code
>>> compiles
>>> fine with mpicc - and runs on the front-end. I guess I need to
>>> find a
>>> trigger that stops this from working..
>>> login1.surveyor:~/junk > mpicc sizeof.c
>>> long double : 16
>>> double      : 8
>>> int         : 4
>>> char        : 1
>>> short       : 2
>>> long        : 4
>>> long long   : 8
>>> int *       : 4
>>> size_t      : 4
>>> Satish
>>>>  Barry
>>>> On Apr 29, 2010, at 8:16 PM, Satish Balay wrote:
>>>>> Its not AIX - looks like its BlueGene/L - and you need --with-
>>>>> batch=1
>>>>> option.
>>>>> For a preconfigured BG/P options list with IBM compilers - check:
>>>>> config/examples/arch-bgp-ibm-opt.py
>>>>> To use PETSc on BG/L with the default GNU compilers - you can try
>>>>> ./configure --with-batch=1 --download-f-blas-lapack=1
>>>>> [and follow instructions as printed by configure]
>>>>> Satish
>>>>> On Thu, 29 Apr 2010, Shree Krishna wrote:
>>>>>> Hi,
>>>>>> I was trying to install Petsc on CCNI ( IBM AIX cluster at
>>>>>> Rensselaer
>>>>>> Polytechnic institute) and it gave me following error.
>>>>>> Unable to determine size of char
>>>>>> I am attaching the configure.log file with this email. Will it be
>>>>>> able for
>>>>>> you to help me configure Petsc.
>>>>>> Thanks.
>>>>>> Shree.
