[petsc-dev] [petsc-maint #45539] petsc installation failure
Satish Balay petsc-maint at mcs.anl.gov
Thu Apr 29 21:20:27 CDT 2010
On Thu, 29 Apr 2010, Barry Smith wrote:
>     THIS IS INSANE! What a stupid useless error message. Why isn't it
> suggesting --with-batch???
>      Well, look what happens -----
> In checkCCompiler() it builds an executable and seems to run without
> error. This is where configure checks for failed running and prints
> the helpful --with-batch option. But since the "execute" succeeds no
> useful error message.
> Then several other executables seem to run fine.
> Then it builds the sizeof(char) test code and that is not executable
> and hence the terrible "Unable to determine ..." error message.
Yes - some code compiled for compute nodes also run on the frontend -
but not all..
>     Satish,
> Does this same problem occur on our BG?
Nope.. I get:
login1.surveyor:~/petsc-release-3.1 > ./configure --with-fc=mpif77
             Configuring PETSc to compile on your system
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:742)                    *******************************************************************************
                    UNABLE to EXECUTE BINARIES for config/configure.py
Cannot run executables created with FC. If this machine uses a batch system
to submit jobs you will need to configure using/configure.py with the additional option  --with-batch.
 Otherwise there is problem with the compilers. Can you compile and run code with your C/C++ (and maybe Fortran) compilers?
> Can you have the original test of the executable in checkCCompiler()
> make a code with a print statement in it and see if that is not
> executable and hence stops with the correct error message?
I have tested with sizeof.c [in src/benchmarks] and this code compiles
fine with mpicc - and runs on the front-end. I guess I need to find a
trigger that stops this from working..
login1.surveyor:~/junk > mpicc sizeof.c
login1.surveyor:~/junk > ./a.out
long double : 16
double      : 8
int         : 4
char        : 1
short       : 2
long        : 4
long long   : 8
int *       : 4
size_t      : 4
Satish
>    Barry
> On Apr 29, 2010, at 8:16 PM, Satish Balay wrote:
> > Its not AIX - looks like its BlueGene/L - and you need --with-batch=1
> > option.
> > For a preconfigured BG/P options list with IBM compilers - check:
> > config/examples/arch-bgp-ibm-opt.py
> > To use PETSc on BG/L with the default GNU compilers - you can try
> > ./configure --with-batch=1 --download-f-blas-lapack=1
> > [and follow instructions as printed by configure]
> > Satish
> > On Thu, 29 Apr 2010, Shree Krishna wrote:
> >> Hi,
> >> I was trying to install Petsc on CCNI ( IBM AIX cluster at Rensselaer
> >> Polytechnic institute) and it gave me following error.
> >> Unable to determine size of char
> >> I am attaching the configure.log file with this email. Will it be
> >> able for
> >> you to help me configure Petsc.
> >> Thanks.
> >> Shree.
