[petsc-dev] ML interface
Jed Brown jed at 59A2.org
Tue Apr 20 11:53:04 CDT 2010
I started updating this interface and I have run into some questions.
1. Many ML options are only present in the C++ interface, via this cool
new API knows as "strings".  These mostly end up just setting
agg_object->named_options which we can do just as well from ml.c.
Unfortunately, there is some nontrivial logic about mutually
exclusive/non-orthogonal options (ML just ignores certain options if
other options are given).  We usually get segfaults if we set
incompatible options.  I think there are cases where the ML C++
interface will also let this through, but it certainly does a more
complete job of ensuring preconditions than we can reasonable expect to
reproduce.  Is it actually worthwhile to use ML's C++ interface
considering that ML is not really developed any more (the devs are
working on a new thing that's a more-or-less complete rewrite)?
2. If we make PETSc's ML interface use C++, I do not want to have to
build all of PETSc with a C++ compiler just to be able to use ML.  Can
we detect a C++ compiler and then just compile *.cc sources with it (I
would also like this to facilitate users building C++ project against a
plain C PETSc)?
3. ML calls exit() directly in many places, despite being an insane
error "handling" mechanism, especially in parallel.  Part of me wants
PETSc to register with atexit() just to be able to provide a stack trace
in this circumstance.  Thoughts?
4. ML_Gen_MultiLevelHierarchy_UsingSmoothedAggr_ReuseExistingAgg()
exists (undocumented of course), so there is a way to avoid rebuilding
the hierarchy at every PCSetUp.
Jed
