[petsc-dev] post 3.1 reorganization of PETSc DMMG code
Mon Apr 5 20:46:37 CDT 2010
On Mon, Apr 5, 2010 at 8:47 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 3 April 2010 23:32, Matthew Knepley <knepley at gmail.com> wrote:
> > Why would you attach an option instead of having an equiv API call?
> Do PETSc have an equivalent API call for every option you can set
> using options database?
I think we do. If we do not, then we should.
> > Strings
> > are ALWAYS a bad interface.
> But they are generic... I would love to to have a
> {KSP|PC|SNES|TS}SetOptions() to pass name,value pairs of options...
> Right now, every time I need it, I have to play with the GLOBAL
> options database.
> Think about MPI_Info ... Without it, the MPI API should be far more
> complex for very little to gain... IMHO, your "ALWAYS" is  a bit
> strong :-)
I am not backing off of this one. I hate MPI_Info. This is exactly what made
the
TSTT Mesh Interface so terrible. Everything was stuck in a property. You
could
not tell anything from the API.
   Matt
> Lisandro Dalcin
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100406/b664276a/attachment.html>
